Question about Life Science Bionet Cardiocare 2000 12 Channel Ecg
Cardiocare 2000 (Bionet) machine won't print full page!
My machine stopped printing the full EKG. It starts and then just stops when the paper is half out. I have tried replacing the paper roll, opening and closing the lid, etc. Any suggestions?
    New Friend:
Hi, if i want to start running unit. after that always on display data error, plz turn off. why? what can i do for that? thax
Posted on Jun 30, 2013
2 Suggested Answers
SOURCE: hi,i have probleme in ekg bionet 2000, when i test it without electrods and start printing,,at first it print signal normal but after a few seconds he show a huge and large line with lot of noises in
We are experts in fixing the Bionet 2000 ekg machines.
1) Is the machine plugged in to the wall when you are getting interference? If so, unplug it
2) Your patient cables may be malfunctioning, do they look damaged?
3) Are the electrodes expired?
4) make sure and prep the patient
If you are still having issues, send the machine to us at Discount Cardiology. We will look at it for free and let you know what is wrong with it. You then would have the option of fixing the machine or having it sent back to you.
Discount Cardiology
www.cardiologyforless.com
Posted on Oct 08, 2012
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
EKG machine not printing properly
hi,
If its mac 1200 then try to check the battery and replace the same. here i have added the part number of the battery. Hi,
Here is its part number 303 44270, 18V 1.4Ah nickel cadmium Battery ,
Jun 07, 2013 | Philips AED FR2+ with Extras
I have a problem in ekg bionet cardiocare 2000. When I test it, the led of ready does not turn and therefore there is no signal measure. I changed the entire cable and the problem continues. Thanks
If you haven't solved the problem yet, most likely you will have to send the unit in for repair. When you first power up the unit the system goes through a self test. "light on then off then on again"
Mar 07, 2013 | Life Science Bionet Cardiocare 2000 12...
EKG / ECG Machines
The noise is because of the mechanics of the printer you have to open it and you will find one dashly is partially broken or not fixed so change it or fix it.
Oct 02, 2012 | Life Science Bionet Cardiocare 2000 12...
AT2+ doesn't print
HI,
Its a common problem with Schiller ECG machine. The battery of your ECG machine is faulty. Even if you are using the machine in AC it uses the battery power. The AC power is only used for charging the battery.
When the machine starts to print the battery will drop down and the printing will stop. This is happening with the machine. It will eject the first paper without printing. its normal. Because the machine starts printing on a fresh page only. In your case the machine is ejecting the first paper. When the machine starts its printing in the second page it will draw a large amount of current from the battery for its thermal printing head. If the battery is not proper then it will suddenly drop the printing. The square box you see is not printed by your ECG machine. Its already printed in the paper of Schiller. With this mark the Machine sense the page.
Its a 12 volt 2.3 AH battery. You will not be able to replace the battery from out side any where. For replacing the same you have to open the machine by removing the screws on its bottom. Be care full with the paper tray while removing the top cover. Also do not use any force to open the top cover because there are connections on the top cover.
Here i have added a link to the battery for Schiller AT2 PLUS
Battery
Ajin
Apr 27, 2012 | Schiller Welch Allyn Cardiovit At 2...
Hi,i have probleme in ekg bionet 2000, when i test it without electrods and start printing,,at first it print signal normal but after a few seconds he show a huge and large line with lot of noises in...
Discount Cardiology
Jan 30, 2012 | Life Science Bionet Cardiocare 2000 12...
Our MAC 1200 ekg machine prints out 1 empty sheet prior to printing the actual ekg. Is there a way to eliminate that first page? It wastes a ton of paper. thanks, Dan
hi,
1.Press the setup Button
2.Select operating mode and press enter.
3. Repatedly perss the down arrow until it reaches to the "START AT QUEUE MARK" and perss enter. Then select NO and press enter ( if it is selected Yes then before each recording the recorder advance the paper to the beginning of the next page)
4. Press the Start button to exit the setup.
From the next EKG it will print from the first page.
ok
Aug 09, 2011 | Ge Medical Systems Ge Marquette Mac 1200...
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
I have an at1 schiller it starts to print in auto mode for like 6 seconds and then stops sometime it prints the full report and sometimes it dont can u assist
hi,
You have to check two things. First you have to check the patient cable, and have to check is its electrodes are properly cleanded or not. if any one of the lead or the electrode have some problem then the machine will stop printing.
Second thing the battery inside the machine. its a 12V 2.3AH battery. If availabel try to replace the same. To replace the battery you have to oppen the machine.
ok
Jul 06, 2011 | Schiller Cardiovit At 1 Ecg Machine
Life Science Bionet Cardiocare 2000 12 Channel Ecg Logo
569 people viewed this question
Top Life Science Medical Experts
Tom Chichester
ka4iup
ka4iup
Are you a Life Science Medical Expert? Answer questions, earn points and help others
