Question about NEC Vivid Office 2020
Error code C-0204
C 0204 error
is there paper behind the draws/ remove it. Remove the paper from the left side of the paper draw IT IS NOT A STORAGE AREA its for 11x17 paper. If not then bad tray lift motor or worse case control board$$$$$$$$$$$$$$$$$
May 28, 2014 | Konica Minolta bizhub C450P Laser Printer
Error code c-0204
remove draw #2 remove the paper behind it. also do not store paper on the left side of the draw. its not a storage area its for 11 x 17 paper.
Jan 22, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code 1000 verizon wireless
Contact verizon for explanation of this code.
.800-922-0204
Mark
Motorola Support
Jan 30, 2013 | Motorola RAZR Cell Phones
Philips universal ir codes
Universal remote codes for Philips are: 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141 For Philips Magnavox are: 0062 0204 0207 0183 0226 0288
Jul 07, 2012 | Televison & Video
Need code to program tv have universal roamoat
Try these codes.
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141 0062 0204 0207 0183 0226 0288
Mar 19, 2012 | Philips Televison & Video
Need help w/ bizhub c350< error code is c-0204
error code c0204 means the yellow drum unit corona has failed the drum unit needs to be replaced this unit may also be called an image unit
Sep 27, 2011 | Office Equipment & Supplies
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Oct 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Got error C-0204 Don't know what that means.
this code means paper tray 2 is not lifting the paper up to the feed rollers.pull the paper out of the tray and make sure it is not folded up the side of the stack if it looks ok then you may have a failed lift motor or bent lift motor bracket
Nov 03, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C352 error code C-0204
I had the same recently.
Problem is caused by a paper which stuck behind the paper tray. It happens when You put to much paper od while moving (for example). Solution: take out the paper tray 1 and 2, remove the paper from the space behind the trays.
Pixel
www.mojito-networks.com
Jul 29, 2008 | Office Equipment & Supplies
NEC Vivid Office 2020 Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
