Question about Kodak i2600 - document scanner
Cannot open scanner - Kodak i2600 - document scanner
The "Open Scanner" won't work on my computer
Will the buttons on the printer work normally? If so, then it's a software or driver problem in the computer.
Jan 23, 2014 | Canon PIXMA MX350 Wireless All-in-One...
Scanner stuck at 000.0000 keys don't work
You may benefit by performing a reset or initialization of the scanner. The manual describes the procedure at the bottom of page 38.
You may lose previously stored frequencies if you reset or initialize the radio.
RESET
1. Turn off the scanner, then turn
it on again.
2. Insert a pointed object, such
as a straightened paper clip,
into the reset opening on the
side of the scanner. Then
gently press the reset button
inside the opening.
Initialize
it on again.
2. Hold down TUNE/CLEAR.
3. While holding down TUNE/
CLEAR, insert a pointed object
(such as a straightened paper
clip) into the reset opening on
the side of the scanner, then
inside the opening. The
display should turn off.
4. When the display turns on
again, release TUNE/CLEAR.
I hope this helps & good luck!
Feb 04, 2013 | Radio Shack Pro-82 200 Channel...
I cannot scan
If you on windows xp, go to My Computer and in the list of drives and devices you will see your scanner icon. Double click to open the scanner dialogue box. From there simply follow the instructions to complete your scan.
If you are on windows Vista, go to start/all programs/windows photo gallery. When it opens click on file/import from scanner or camera. The dialogue opens for you to select your scanner. The scanner dialogue box opens and simply follow the instructions to complete your scan.
Good luck & God bless!
Nov 23, 2010 | HP J3680 Officejet All In One Printer
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
Scanner error 20
1)open your printer door and see right side corner 2) 2 ribbon cables and one metal sheet 3) press the matel sheet propely and close your printer door 4) swithch off and on
Jul 21, 2009 | HP LaserJet M1005 All-In-One Printer
How do I uninstall my HP 5500c scanner ..I have a Mac os X
use following instruction and uninstall the scanner.
open the control panel
2-open add/remove program
3-click on scanner and then remove...
Apr 13, 2009 | HP Scanjet 5500c Flatbed Scanner
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
Can't figure out how to open the case
There may be lock system rather than a screw. Please see the lock and it will be opened by pressing a lock node(s) or aplying the force in a paticular direction. Do not try to open force fully. Refer manual of scanner if there are instruction to open the case.
Aug 23, 2007 | HP ScanJet 3300Cse Flatbed Scanner
Kodak i2600 - document scanner Logo
70 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
