Question about Grundig FR200 AM/FM/SW/DAB Radio
In the space for the single battery, the metal coil that presses
Against the battery came out and isn't quite straight. I tried to straighten it out and fit it back into the slot but it still doesn't work. Shouldn't the flat part of the battery go against the coil? Can I fix it myself. When I crank it the light indicating that cranking is taking place lights but the light on the radio itself doesn't light?
  • inalabiner Feb 04, 2009
    I cranked it as directed (battery light was on) but nothing played. I called manufacturer who suggested that it might need a new green permanent battery (that I might try to get at Radio Shack) that they could send me. So why does the light on top go on but no radio?
The problem was solved when I threw the radio away and bought a new one. The suggestions were of no use and I'm asking for a refund.
Posted on Feb 17, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding your radio has two separate circuitry; the radio itself and the powersupply unit composed of the battery, the charging (by cranking) circuitry. You would need a voltmeter (DVM/VOM) to check if the battery is charging; crank the unit for a few times to allow the battery to charge. Remove the battery and check if the voltage specified is present.
  • If it is and when placed back into the slot, the unit does not operate, then the radio side of the unit has to be attended to. This would mean opening the unit for a look & see. This could be as simple as a corroded terminal/connection or a faulty component such as a reverse protection diode;
  • If it is not, then the battery itself would no longer accept a charge and would require replacement.
Good luck and thank you for using FixYa.
Posted on Feb 04, 2009
  • Louie  Role
    Louie Role Feb 04, 2009
    Of course, another possibility is that the terminals/battery connector of the radio is corroded. It would then require cleaning and in some instances scraping to expose fresh metal.
  • 10,515 Answers
I am sorry to accept the reply that was given by most of the experts...
"Change the battery"....Only solution :)
Thnx.
  • Grundig Master
  • 19,396 Answers
Bend the part back to the original shape to fit back the battery, if the battery had been damaged, contact the phone number listed on the owner manual to get a replacement part.
Posted on Jan 30, 2009
  • Ginko
    Ginko Feb 04, 2009
    The light may come on, but the radio may still not working because the battery is faulty.
    You need to test with the new battery.
  • Ginko
    Ginko Feb 05, 2009
    Let us know if you solved the problem or if you need further help.
    Sergeant:
  • 250 Answers
Try to fix it inside as mostly it is not loose internally it is fixed tight.so it will not work if just kept inside as it should also be touching the board inside.
Posted on Jan 29, 2009
    Sergeant:
  • 378 Answers
Its connected internally the unit needs to be opened and the metal part has to be soldered on the circuit board to make it work.
    President:
  • 1,990 Answers
Welcome to Fixya! You can Bend this Back in Place and Yes the Battery is Correct. It will take a While of Cranking to get it to Light If the Power light is coming on. Please Rate my Solution, I need all the Help that I can Get! Thanks!
I have a casio pathfinder model 2273 and the light went out. I changed the batteries, but still no luck. Everything else seems to work just fine.
Hi Jennifer
Two possibiities here one is electronic, unlikely but possible, and one mechanical that you can check.
When you changed the batteries did you notice internally the location of the button that turns the back light on? If you pressed the light button, did the button or a spindle move forward towards the body of the watch? did you notice a contact? or nothing pressed against anything?
When changing the batteries you would have click open the battery holding frame. This frame or internal back plate has around the light button a little piece of metal, like a finger that gets pressed by the button towards a contact in the body of the watch. This finger suffers metal fatigue and quite often looses its springiness or snaps altogether and loses it ability to make contact between the frame and the EL plate that illuminates the back of the watch.
If you are missing this contact perhaps you could buy a replacement plate from Casio. Can not advise as to the costs of doing it yourself or sending it to Casio. It is fiddly job.
Hope this helps
Nov 27, 2016 | Casio Watches
When going over deep grass there is a metal sound. It's like the blade is hitting against something. Is this a common problem with this model? How could I fix this issue?
Hi Andrew:
It is quite possible that the blade is bent or the metal "grass discharge guide" has been damaged.
If you have a pickup truck handy and you can put the mower facing outward on the tailgate, this procedure is easier.
- remove the spark plug lead to ensure that the mower cannot accidentally start.
- Push the handle down so that the mower is tilted back and the underside of the cutting deck is exposed.
- slowly rotate the blade and see where it contacts (or has been contacting any metal parts.
- remove and replace the blade if it has been bent. (They can be straightened but it is not recommended)
- Use 2 hammers (one as a "dolly") to straighten or repair any bent sheet metal.
- Replace the plug lead and go cut grass.
Cheers
Apr 27, 2016 | Garden
Dvd is jammed
If the DVD player/drive door or drawer will not open, try taking a regular metal paper clip, straightening it out, and inserting it into the small hole that releases the cover. Use a flashlight to look for this little hole, insert the paper clip straight in, and press firmly. The door/drawer should come open.
Oct 21, 2013 | Computers & Internet
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
Gun will not shoot nails completely;no matter what wood,thickness,etc.they drive all but 1/2"
May be due to broken tip. Easy to check. Remove nails and leave door open. With door open, lightly tap the nose of the gun against coiled rubber hose or soft wood. The driver should stay at top position. If driver falls to bottom of the cylinder, replace piston oring. Now press nose of the gun against old coiled up air hose or soft wood and squeeze and hold trigger. The gun will fire and the driver should stay in the down position untill you release the trigger (if not single fire trigger, if single fire trigger remove trigger and press the trigger pin with finger). While the driver is down, make sure that the tip extends past the nose about 1/4 inch (if air leaks past the nose in this position, replace lower bumper). If the driver does not extend past the nose, replace driver. Good luck
Jun 24, 2011 | Stanley Bostitch N75c1 Coil Sheathing...
How do you use a conair straightener? what does the dial with the numbers mean?
The settings 1-10 are for wet and easy-to straighten hair. Like hair that is a little thinner or almost straight.
The settings 11-17 are for damp hair that is about average thickness.
The settings 18-23 are for hair that is thick or wavy.
Lastly, the settings 24-30 are for dry hair that is harder to straighten.
So, the higher up you go, the higher the difficulty the hair is.
Hope this helps! :]
May 31, 2011 | Conair Health & Beauty
I pulled the spark plug out and left it to the wire to see if it had spark and it dont so is there anyway to check the coil or could it be somethin else
The metal on the outside of the plug must be pressed against the cylinder in order for a spark to happen. If you did ground the plug as described, and no spark was present, try a new spark plug. Carbon on the nose of the plug can rob the spark. If still no spark, check the fuses with a multimeter then check for power to the coil. Battery weak or dead?
Apr 09, 2011 | 2001 Gas Gas EC 300
I have a canon a 560 displaying low battery even thought i checked and confirmed that the batteries were in good condition.
Here is the suggestion:
The battery compartment cover and the design of the metal electrical contacts is flawed. These acontacts re made of springy metal, but there isn't enough force to press the metal securely against the battery. The end of each contact has a metal tab that prevents it from being bent further out to increase the tension. These contacts are the cause of the low-battery warning.
Some fixed the camera by inserting tiny pieces of plastic foam (i.e., spongy, like from "foam rubber" pillows) under the metal contacts. Used a small screwdriver to gently bend up each metal strip, and stuffed a small piece of foam under it. This provides enough force to keep the contact securely touching the battery.
or You can also try the "toothpick trick" as described in various forums, and it seems to be working. There is a belief that there is a design flaw with the battery compartment door, or the springs that press against the battery. By wedging a toothpick under the battery contacts, it seems to force the contacts into the battery, seemingly helping with the problem that many are facing in this and other forums.
Mar 09, 2011 | Canon PowerShot A560 Digital Camera
My Canon claims that I need to change the batteries. However, I have changed them out 3 times with brand new batteries. It is now dead and won't turn on.
Nov 08, 2010 | Canon PowerShot A560 Digital Camera
Aquabot goes in one direction
Find a looooong straight area and, starting from the Aquabot, hold the cord straight and straighten it out by letting the cord twist so it isn't all gnarled and twisted - move down the cord, always keeping one hand firmly on the end of the cord closest to the machine (to prevent it from re-twisting). You'll find that the cord will spin like a top as you get closer to the end. Once untangled, pull down on the metal rings under each end of the top floating handle (may require a pull and a slap against the handle). MAKE SURE THE HANDLE IS LOCKED IN A DIAGONAL POSITION.
Jun 17, 2009 | Aquabot Turbo Robotic Pool Cleaner
Grundig FR200 AM/FM/SW/DAB Radio Logo
50 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
