Question about Philips Televison & Video
How do I access full menu for setup Phillips 32HF7965D/27
TV powers on. Menu offered is not the full menu. Can't get to "language" for setup.
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
dsacco86
  • 1077 Answers
SOURCE: phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Posted on Aug 03, 2009
57 varieties
  • 1653 Answers
SOURCE: I bought a 32LC5DC Lg
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
Posted on Oct 01, 2009
  • 6 Answers
SOURCE: SAMSUNG LE32R73BDX/XEU TV
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
tlm931
  • 273 Answers
SOURCE: My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Posted on Oct 31, 2009
I wanna change the language of my Sony Bravia KDL40V2500 from japanese to english and i can't do it. How can i?
Most language options on electronics are found under "Settings"
Switch on
Menu
Settings
Preference
Language
Sep 22, 2015 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My tv rca model # 32668 is in a different language, I need to change it back to English without the remote. Please help
Hello there ,
The user guide can be downloaded here
http://www.manualslib.com/download/508120/Rca-F32668yx53.html
From the page 28 of the guide.
1) Push 'menu' button of front panel of tv.. This will bring up the menu on the tv screen..
2) Using the 'ch' buttons next to menu button, move up or down to highlight number 8 'setup'
3)press 'menu' button again then 'begin setup now' should appear and be highlighted.
4) Press 'menu again which will take you to 'language'
5) use the 'ch' buttons to move up or down to highlight 'English'
6) press 'menu' again to select english as the language.
That should be it.
If you get problems, read the user guide and follow it carefully.
Good luck
Sep 12, 2014 | Televison & Video
How to change language to English
If you're lucky it only has active powered memory, unplug the tv and click the start button a few times to discharge, plug back in and go through the initial setup.
May 10, 2014 | Toshiba 32D46 32" TV
I can't access my main menu for my Phillips TV
The TV might have set to Hotel mode. To get it out from this mode, you have to enter its service alignment mode [SAM]. Check this link to get more details about it. It is too much to type in here, al the procedure. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 03, 2013 | Televison & Video
How do i reset audio language on tv?
Go to setup menu on the TV using the remote and select English from the language option and press OK. You may need to browse through the setup menu to locate the language option.
Jun 26, 2013 | Westinghouse Televison & Video
Toshiba 32BL505B- 32 inch TV - Lack of settings - No Installation, or TV Settings.. Please Help
1. Press the menu button on the remote
2. Once the menu comes up press the numbers 7935 in succesion
3. This should bring up the hotel menu, turn off the hotel mode at the top of this screen
4. Then press the menu button to exit out of the menu and next time you press the menu button there should 6 icons available
Jan 10, 2013 | Televison & Video
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
How to change language on motorrola hk100
All Motorola cell phones have the ability to change language settings. This adjusts all of the phrasing and words throughout the cell phone's menu, as well as the prompts that appear on the screen. This allows the phones to be easily produced and marketed to other countries around the world. With this included feature, it is possible to change the current language to another language in just a few easy steps.
11.Power on the Motorola cell phone.
2.Highlight "Main Menu" and press the "Select" (or "OK") button.
3.Choose "Initial Setup" on the new menu by pressing the "Select" button. The display menu changes once again to setup options for the phone.
4.Scroll down to "Language." Press "Select" and all of the available languages appear on the cell-phone screen.
5.Select the language you want on your phone, then press "OK."
I hope this helps. Thank you for using FixYa
Oct 18, 2011 | Cell Phones
We own a samsung flat screen HD tv, model: Ln46C530, software version: T-TDT5A6SC-10060. At the bottom of the screen there's line of windows that pop up, they say, series 5, wide color enhancer, hyper...
It sounds like you have the Store Demo Mode on. To turn this off, press the volume button. While the volume is displayed in the OSD (onscreen display), press and hold Menu for 5 seconds (or a bit longer).
Alternatively, you can find this in the menu. When TV is the source, press Menu > Setup > Plug & Play followed by Enter. (It's the second choice after Language.)
The manual is available here: http://www.samsung.com/us/support/downloads/LN46C530F1FXZA . This is on page 7.
I hope this helps.
Jun 16, 2011 | Samsung LN46C530 TV
Can't change language on siemens a55 back to english
PLease follow the steps below to reset the language on a Siemens A55.
Enter the 'Setup' menu option.
From the menu, enter the 'Phone' option,
Select 'Language'
If 'Automatic' is selected it will set the language normally used by your network.
You can also scroll through and select 'English' manually.
May 09, 2011 | Cell Phones
Televison & Video Logo
97 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
