Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
DU1100 XTPS DIshwasher
Our Dishwasher's door doesn't seem to latch on and automatically close when we start the cycle. Is there a way to fix this with out calling someone? Its just 3 months old... Everything else seems to be ok.
    Novelist:
  • 159 Answers
I would make sure that the lever on the dishwasher body is not bent in any way. If it is you can straighten it out and then make sure the door close's properly. But for being 3 months old I would give whirlpool a call and have them send a repairman out. There will be no charge to you seeing its under there warrenty.
Posted on Jul 22, 2007
SOURCE:
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Less that 2 yrs old..door wont latch. As a consequence machine won't start.
It is possible the door latch is faulty or the springs at base of dishwasher are soft and need adjusting. the springs keep the door in position. refer this site for parts.
Dec 31, 2012 | KitchenAid KUDS30IXBL Builtin Dishwasher
The touch bottons are clicking on and off and nothing works. I had to shut the washer off in a hurry recently and this is the result.
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.Is there power to the dishwasher Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.Does your dishwasher have a rotary timer knob? (Some Models)The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.Is the control lock option activated?Press and hold the Heated Dry option (button with lock icon) for three to five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.Is the delay start option activated?To cancel the delay and cycle, press Cancel/Drain.Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.Is the Start/Resume indicator flashing?Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.Is the water shutoff valve (if installed) turned on?Make sure that the water shutoff valve is turned on
Sep 10, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My Maytag QuietSeries 400 dishwasher won't start. Sometimes 88 flashes on the display and that's all. What does that mean? Model # MDB7601AWB
Dishwasher will not start Is the door open or unlatched?
Make sure that the water shutoff valve is turned on.
Jun 19, 2011 | Maytag Dishwasher
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
My dishwasher will not start its cycle
Is there power to the dishwasher?
electricity ground dishwasher.
Connect ground wire to green ground connector in terminal box.
Donot use an extension cord.
Failure to follow these instructions can result in death,fire,or electrical shock.
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
216 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
