Question about Discovery Channel Discovery Kids - Rocket Ship Projection Clock
How do I reset alarm? - Discovery Channel Discovery Kids - Rocket Ship Projection Clock
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
1. Press the Alarm Set button to display the current alarm.
2. Hold down the Alarm Set button for a few seconds. This will cause the time to flash.
3. Press the Up/Down buttons to reset the new time.
4. Press Alarm button once more to set minutes. Press again to exit alarm setup.
Cheers!
Posted on Apr 28, 2013
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Feb 04, 2011 | Audio Players & Recorders
My husband would like the alarm off. i don't know how i did it but i set the alarm. please help me remove the alarm setting. thank you.
* Press the MODE button until you are in ALARM mode
* Press STOP/RESET (-) or START/SPLIT (+) to cycle through alarms
* When you have selected the alarm you wish to erase, hold down STOP/RESET (-) to clear the selected alarm
Aug 19, 2010 | Timex Watches
I have a 1999 jeep grand cherokee. the alarm goes off whenever i open the door if the vehicle has been locked the alarm stops when i start the vehicle i only have a key, no remote any ideas on how to fix...
If ithe alarm is factory when they will have to reset the alarm module with a scanner. If the alarm if aftermarket go to the control module and see if it has a reset button. FOBs (remote) can reset alarm. You Jeep is always set for break-in mode. The FOB sets this when ever the FOB is used to lock the doors. May be bad alarm module - Sorry - Good luck
Oct 17, 2009 | 1995 Jeep Grand Cherokee
How do I reset factory alarm on a 2000 Subaru
you HAVE to get a remote and unlock the car.the dealer may be able to turn it off with the obd2 system,you have to call subaru.
Jul 13, 2009 | 2000 Subaru Legacy
Car: 3 series BMW - Problem I can't reset the alarm
BMW 3 series 2007. Have changed tires, but cannot reset air pressure alarm ?!
Mar 26, 2009 | Anti-theft Alarm System 3 Series E90 E92...
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Factory alarm
the only way to reset an alarm is to disconnect the battery cables.
there is no such thing as an alarm reset switch.
My suggestion would be to go to autozone, they sell replacement key pads.
Aug 04, 2008 | 1998 Ford Contour
Soundesign 316G Jukebox Alarm Clock-can't set alarm
Press the alarm reset ( on/off ) for a few seconds.
Same as you do to set the time
Feb 13, 2008 | Novelty Simpson Jukebox Alarm Clock Radio...
Issues with samsung u340
on the options menu for the alarms instead of clicking to reset a single alarm you must reset all alarms at once.. worked on mine anyway.. wish you luck
Aug 02, 2007 | Samsung SCH-u340 Cellular Phone
Discovery Channel Discovery Kids - Rocket Ship Projection Clock Logo
426 people viewed this question
Top Discovery Channel Audio Players & Recorders Experts
Jeannie Martin
Level 1 Expert
Brett Hondow
Brett Hondow
Level 1 Expert
Are you a Discovery Channel Audio Player and Recorder Expert? Answer questions, earn points and help others
