Front loader spins at high speed, clothes still soaking wet? why?
THE SPIN CYCLE DOES SPIN AT MAXIMUM SPEED. I THINK THE LONGER THEY SIT IN THE WASHER AFTER THE CYCLE IS DONE, THE WETTER THEY GET. IS THIS POSSIBLE? I'M NOT SURE THOUGH.
  • 4 Answers
I think the water is syphoning back from your waste outlet make sure the waste pipe is installed correctly
Posted on Jan 22, 2013
  • Sandy Russell
    Sandy Russell Jan 22, 2013
    I don't know how it couldn't be. I've had it for 5 years now. Thanks anyways! :)
  • paul smith Jan 23, 2013
    It can suddenly happen for no reason this is the world of washing machines
3 Suggested Answers
SOURCE: washer works fine up until final high speed spin,
how can i fix it
Posted on Apr 20, 2009
localwonder
  • 6784 Answers
SOURCE: clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Posted on Jun 10, 2009
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Washer will not spin at high speed
check for any blockages around pump and air trap area.
Sep 14, 2009 | GE WBSR3140DW Top Load Washer
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Machine won't run the spin cycle
It is most likely a defective speed control or a defective timer. Pull out the timer and clean all metal connections first and if it doesn't work then that is the cheapest part to replace first and see if it is causing the problem. Loose connections or bad wiring might be a possibility as well.
Sep 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
