Question about Carrera 6 Sunglasses
Lost screw holding in the lens for a Carrera 6
The lens popped out on my Carrera 6 that I bought less than 3 months ago, and now I can't find the screw. I went to the Carrera website and could not find any information regarding warranty or customer service. How would I go about getting a replacement screw?
    New Friend:
  • 141 Answers
Just go to an optichons like exspres sory but i can not spel to go but this shuod solve it for you
Posted on Jan 22, 2013
Suddenly, No tail lights, brake lights, turns signal or back up lights At 83000 miles, 6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen...
just look for the blackened/burned pin on the rear light plastic connector and sand it down to re-establish a good electrical connection and save yourself $800 big ones on replacing the multiswitch.
Jun 26, 2011 | 1999 Chevrolet Venture
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Machine has been off for 6 months. Plugged it
If you mean the LCD is only partly showing, it should be replaced. Just sent in two for the same problem with clients. Apparently, supplier switched to cheaper parts, causing this. Should be under warrantee. Call fast. If you never set up the warrantee, you should do that first. I'm "SURE" you bought it less than 3 years ago...Right???? (Hint) 800-989-2299
Sep 21, 2009 | Ecoquest Fresh Air Air Purifier
Dvd stops playing and freezes less than 6 months old
Try to use lens cleaner. If lens cleaner doesnt solve the problem. Check your warranty. Or inquire to the store where you bought it.
May 14, 2009 | TruTech PVS12701 Portable DVD Player
Lens Wont Retract
mine does the same thing. i just bought it like 2 months ago too. what could it be? i don't want to have to ship it back, but it looks that way so far. i bought new batts. too and that did nothing. also i called sony, and spoke w/ tech support, and they had me take out the batteries, hold down the power button for 30 secs and then put the batts. back in. ??? i was like what will that do and she said reset it, but it still won't power on and the lens is out. it beeps like duhduh and then goes back off. it is making me mad. b/c also i have bought 2 sony PS2's and they both quit reading games. what is with sony? can someone help us w/ the camera problem? thanks!
Mar 24, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Polaroid i533 digital camera
Here is how I fixed this problem. I grasped the lens around the base (larger part) like you would if you were going take off a beer bottle cap.
Very gently while sliding my thumb and index finger around the lens, I rocked it back and forth. DO NOT TRY TO TWIST OR PUSH,.....It felt like it "popped" back on track.
My assumption was it was probably hit from the side, and could not retract, once it was rocked back on track, it worked fine. It felt like it loosened a tiny bit as well.
Good luck.
Jan 03, 2008 | Polaroid I533P Digital Camera
LG KG 800 slide
it is a pain to open these. 1. remove the battery & undo the 4 black screws. LG use a thread locking compound (loctite) on all the screws so they will be a **** to undo. 2.Prise the back cover off. 3. Pop apart the 2 rectangular connectors at the top of the keypad circuit board. 4. Lift the top board slightly & pop apart the ribbon/flex cable from the top board. The big silver bit comes off with the flex cable. There is a small bit of adhesive on this so be gentle. 5. undo the 6 silver screws holding the slide mechanism together & lift the slide off over the flex cable. 6. pop the 2 screw covers off the top of the phone then undo the 6 screws holding the front cover on. 7. pop the flex cable off. then the touch pad connector. then the camera lens connector. Gently pull the screen circuit board out of the front cover. Careful as sometimes the speaker is glued in place. 8. Unclip the lcd connector & gently remove the small battery looking thing (it's got red & blue wires on it) from the back of the lcd panel. It's glued on. Have fun. It took me ages to work this out.
Aug 05, 2007 | LG KG800 Cellular Phone
Carrera 6 Sunglasses Logo
135 people viewed this question
Top Carrera Clothing Accessories Experts
Da Doc
ray gallant
Are you a Carrera Clothing Accessory Expert? Answer questions, earn points and help others
