Question about Sanyo Televison & Video
Codes for sanyo tv model # DP26647, trying to program a directv remote to work tv
Model # DP 26647
SOURCE: Remote control programming- Directv
if you have gone through all of the programming codes; you will just have to use the remote that came with the TV set. there is no way to program more codes into the remote, due to its list of codes it was made with can not be updated. i hope this helps
Posted on Feb 02, 2009
gcrcomputers
  • 170 Answers
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
SOURCE: directv remote codes
go to menu
setup
setup again
remote
tv
brand
the satelite receiver will tell you the procedure for programing the remote
Posted on Apr 03, 2009
SOURCE: programming my directv remote to operate this tv, codes dont work
I just programmed mine by using my direct tv remote...
Go to MENU on the direct tv remote
Then highlight HELP & SETTING and press SELECT.
Press SELECT on Remote in the left menu.
Simply follow the onscreen instructions to program your remote. IT IS IMPORTANT TO MAKE SURE YOU HOLD ON AND SEE THE GREEN LIGHT ON THE DIRECT TV REMOTE FLASH TWICE, otherwise it won't work....which is what I think is happening in your case. Good luck.
Posted on May 10, 2009
SOURCE: Trying to program my Directv (tivo) remote to new
I read another post where they added 1 to make the code 5 digits. Use 01331 and try it, it worked on my Directv Tivo remote and Proscan 32".
Posted on Sep 13, 2009
Why do I have to go all the way through my tv hookup (HDMI 1,HDMI2 etc)to get sound. I just hooked up to directv and it used to work fine.
Sounds like the TV do not save the LPM (Last Position Memory). Contact the authorized service centre. If the main system control memory IC has any fault, this might happen. Electro help
Nov 18, 2014 | Sanyo DP26647 DP42647 DP50747 Remote...
Sanyo vizon model clt1554
I think you are asking about the Directv remote codes to control your tv,if so you can get those from the directv site.Look under remote control programming and select your tv or device.It will give you the most used codes
Jun 18, 2014 | RCA Direc Tv Remote Control Model Crk76sg4...
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Oct 24, 2009 | Philips Televison & Video
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
Programming my directv remote to operate this tv, codes dont work
Apr 22, 2009 | Sanyo DP42848 LCD TV
Directv remote won't turn on tv or control volume
I am a installer and 10154 works wth every Sanyo TV whether it is HDTV or a SDTV that I have encountered. Try this code using same method above but do not enter 911 but rather 10154. It should work!
Apr 02, 2009 | Directv RC23 Remote Control
Finding codes
how program my control sanyo for tv curtis mathes
Sep 12, 2008 | RCA DIRECTV Satellite Remote Control
Code for tv remote
Try these codes. One of them should work:
017
021
039
056
057
058
Apr 10, 2008 | Sanyo DS27930 27" TV
Televison & Video Logo
47 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
