Question about Indesit BAAN134S
How do you reverse the doors on my indesit BAAN12-WH fridge freezer
I have an indesit fridge freezer and its only 8 months old and the freezer part is starting to freeze where i cant hardly open the shelves otherwise the rest of the fridge freezer is ok what can i do
-Remove every thing you have in there. Open its door and then unplug the power cord. Leave it open and unplug for 1 day or until all ice melt down and then clean up. (Do Not use any shape edge like knife, screws driver to scratch or remove any ice! It'll damage the Freon system.) If the shape object need to be used then you'll get NEW Fridge soon.
Dry it up and then plug back again.
-Make sure set the temperature knob to normal Only. (not the coldest) This will eliminate to build ice faster than normal.
Good luck
Mai
Jan 24, 2017 | Indesit Refrigerators
Should fan run constant on indesit ban12fn fridge freezer?
It should shut off when it reaches the correct temperature. If you have the temp set to low it could cause it to continue to run or if there is an issue with the fridge that could also cause this issue. Keep in mind after a defrost it will take some time for everything to get back to the correct temp so it may run constant for a long time.
Jun 09, 2015 | Indesit Refrigerators
Hi, got a fridge freezer, the freezer door is not closing -please help
check if noting broke in the door locking mechanic. Or check if not too much ice is pressing the door open.
But if you don't hear the click, check the lock.
Feb 26, 2015 | Bosch Kge Series Fridge Freezer Door...
Indesit fridge/freezer starting & stoping
The compressor is supposed to start & stop, it wont run all the time.
Nov 22, 2013 | Amana ABB1927DE Bottom Freezer...
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
Fridge is running but won't get cold
if it have one compressor the gas in the system are low . but if it have 2 compressors the thermostat can be the problem
Jun 01, 2009 | Refrigerators
My indesit freezer in on amber light on 1 and it is too cold should the light be showing amber
check to see if you dont have unit on quickfreeze.or possibly the thstat is set to high or control is faulty
Jan 03, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Indesit Fridge Freezer
YOUR DEFROST TIMER OR A BURN OUT DEFROST ELEMENT
Oct 17, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit BAAN134S Logo
66 people viewed this question
Top Indesit Refrigerators Experts
Dado
Brian Coughlan
John Tripp
John Tripp
Are you an Indesit Refrigerator Expert? Answer questions, earn points and help others
