Question about Pool & Spa
How to remove the impeller from a honda gx160 trash pump
3 Suggested Answers
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
  • 885 Answers
SOURCE: How do you remove the impeller on a honda wt40x
The impeller is threaded onto the crankshaft. Pull the spark plug wire then turn the motor until you are coming up on the compression stroke and the vanes of the impeller are mostly vertical. At about two o'clock on the pump bell there should be a port so you can put a metal rod through it, resting it against one of the vanes at the top of the impeller. Go to http://powerequipment.honda.com/pumps/models/wt40 and about half way down the page it shows the "Easy quick cleanout port" feature. This is how you should be set up to turn the impeller counter-clockwise to turn it off. The use of a dead blow hammer or one similar to the one in the Honda picture is recommended as the impeller is cast and a steel hammer may cause the impeller to crack. Put the new one on tight but don't worry about overdoing it, the motor spins in a self tightening direction so it'll get tighter with use.
Posted on Feb 23, 2012
How do I remover the impeller on a Champion 66520 semi trash water pump
You are going to have to use a puller for that. Look for holes in the impeller that are threaded for use with a puller. If there are none then you may need to use a puller that reaches around the whole unit. make sure you don't load the shaft though when you do this.
Oct 05, 2015 | Pool & Spa
Torque setting cylinder head bolt
Try posting in the automotive area! You should get somebody there that can help.
Jun 25, 2013 | Honda Horizontal OHV Engine for Non Pumps ...
Low water flo
TRASH OR LEAVES IN YOUR PUMPS IMPELLER, FILTER NEEDS CLEANING OR REPLACEMENT, REMOVE CARTRIDGE FILTER RUN PUMP. THIS WILL TELL YOU MORE
.JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 07, 2012 | Hayward SAND FILTER, PRO SERIES
Clog in pool line
TRASH IN YOUR IMPELLER OR WORN PUMP, TAKE PUMP AND SPLIT IT LOOK TO SEE IF YOU HAVE TRASH IN YOUR IMPELLER AND LOOK AT OTHER PARTS FOR WEAR .. PRIME THE PUMP W/ WATER AFTER ANY PUMP REPAIR !!
May 06, 2012 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do you remove the impeller on a honda wt40x trash pump?
Feb 22, 2012 | Tools & Hardware - Others
My pump is humming but not pumping the water, what is the problem?
You are right, it is not running since there is no water
that goes out. It is just humming - which be due to
stucked impeller or busted starting capacitor. Let's start with checking up the impeller. Unscrew the strainer, and take it off. At the suction port, try turning the impeller by your finger. This is to check if it is stucked. If it is stucked, open the bolt holding the impeller case, so that you can free the impeller from
being stucked. Once the impeller is free, you can assemble the pump and switch it on and make it run.
If it doesn't run, then the final touch is to replace the
starting capacitor at the topcase of trash pump. In
doing this, make sure that in the reassembly of the top case, you must maintain the right force to close
the top case bolts water tight. Just send you e-mail
for further assistance. God Bless you.
Oct 26, 2009 | Tsurumi Pump s Submersible Trash Pump -...
How to remove water pump from honda 450x 2007
Remove impeller using a 10mm socket. It is a standard thread so nothing special needs to be done.get back to me if need more info270204a.jpg
Oct 11, 2009 | 2005 Honda CRF 450 X
2" honda trash pump haw no presure
Maybe you trashed it. Take the cover off and look for any debris in the impeller. Also make sure you don't have any air leaks on the intake side of the pump. If the pump is ok and the engine bogs under load then the high speed jet could be out of adjustment or junk i the carb. Remember don't run the pump dry. You can also try adjusting the jet while it is running. Remember turn the needle slowly until it runs better.
Sep 12, 2009 | Honda Water Pump Honda Engine
Pool & Spa Logo
326 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
