Question about Philips DVDR70 DVD Recorder
How do you get past the copy-protected on rec videos
Tring to change videos to disc keeps comeing up copy-protected
Is it possible to play a video on avtex tv and copy it on disc on my laptop
there are copy right protection protocals that are really gonna fight to keep you from doing that, short answer: no
Feb 23, 2013 | Acer Aspire Computers & Internet
I bought a panasonic hdd recorder yesteray i rec a movie last night now need to copy to disc it takes about 3hours to put on disc because it says carnt do it in high speed do i have to turn anything of in...
read your manual, some movies and some disc can't be recorded at higher speeds due to the amount of content in them. You can try the modes, but this has to be done before you start the recording.
Mar 10, 2011 | Televison & Video
I would like to make a copy from my video tape to a DVD How do I do it?
Turn on the TV and set it to the video source to be able to easily see the menus as you set up the dubbing process. Put the source tape you want to record in the VCR. (Copy protected tapes will not be dubbed.) If you want to avoid dubbing from the DVD to the VHS tape, remove the erase protection tab from the cassette. Put a compatible recordable disc (non-finalized disc, unprotected disc) in the recorder and make sure there is sufficient available capacity on the disc.
Press Rec Mode/Speed to set the speed (SP, LP, SLP, or XP). Press DVD/VCR and set the unit to VCR mode. Confirm the mode with the indicator light on the unit. Press Dubbing and the mode should switch to DVD automatically. Select Yes (with the left/right arrows) and press Enter to start the duplication. The unit should indicate the VCR playback, dub and DVD recording are in progress. Press Stop to halt the dubbing process or it will stop when the unit reached the end of the tape or the disc is full.
The dubbing button is only on the remote control; if your original remote isn't working make sure that your replacement remote has the feature. Remotes.com often has exact or substitute remotes with the matching features. Search just by the model number not the brand.
BTW: the manual is available here: http://www.managemylife.com/mmh/owner_manuals/26967/SANSUI-DVD-VCR-Combo-L0311311?brand_name_search=sansui+VRDVD4005 .
I hope this helps.
Nov 11, 2010 | Sansui VRDVD4005 DVD Player/VCR
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Can't figure out where to plug in the transmitter
if the unit your tring to connect has RCA style plugs you can plug them in to the tape REC out connections on the back of the reciever.
Once you turn the reciever on an select your source it will out put on the tape REC out which in turn sends signal to the wireless device.
if the unit your tring to connect has a 1/8" or 1/4" plug you have to convert to RCA or plug into the 1/4" headphone conncetion on the front of the unit
Jul 01, 2009 | Audio Players & Recorders
HPProductAssistant keeps tring to install, even thought i don't want it. I checked add/remove programs and can not get rid of it? Very annoying, please help. Thank you.
Sep 9, 2008 22:35:17 GMT Unassigned Here's the fix, run it and remove the hpprodutassistant entry. It works, I struggled with this a long time.
http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
Copy entire link, paste into browser, install and run.
Jul 31, 2008 | Computers & Internet
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
Not recording a full film
1. Insert disc.
2. Press "DVD" button on remote.
3. Press "REC MODE/REC SPEED" button.
4. Keep pressing until desired recording speed.
I believe your problem is that the movie exceeds the 120 minute limit on the target disc at the default recording speed (SP). Try LP instead.
Nov 18, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Philips DVDR70 DVD Recorder Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
