Question about Xerox Phaser 6010n Laser Printer - Color - 600 X 600dpi Print - Plain Paper Print - Desktop. Phaser 6010 Clr Laser 12/15ppm 1200x1200dpi Ltr/lgl Usb/enet 110v C-lasr. 15ppm Mono/12ppm Color Print - 160 Sheets Input - Manual Duplex Print - Lcd - Fast Ethern
6010 xerox phaser print job sent not printed
Why won't it print? Computer says print job is sent and received by printer but printer does not print. connected to network, downloaded driver, checked cables, checked and rechecked printer settings, new from box.
  • keith644
    keith644 Jan 24, 2013
    Using a MAC with latest OS.
3 Suggested Answers
SOURCE: Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
  • 10 Answers
SOURCE: Xerox system error 09,035,43:46300.
This is from the service manual
Harry
9,035.43 through 9,038 (8500/8550/8560 only):
Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Troubleshooting Procedure for Ink Loader
Step Questions and Actions Yes No
Is the ink Genuine Xerox? Are they the
correct sticks for the model?
Go to Step 2. 1. Advise customer.
2. Replace the Ink
with Xerox Ink.
3. Run Clear ISC
Fault
test to clear
the error. The
Clear ISC Fault is
located in the
Internal
Diagnostics
Function menu.
2 Manually verify that the ink stick is able
to advance in the ink loader chute.
Check for broken or wrong type ink
sticks.
Go to Step 3. 1. Remove any
blockage and/or
replace the ink
stick.
2. Replace the Ink
Loader.
3. Run Clear ISC
Fault
test to clear
the error
Posted on Aug 25, 2010
Phaser 6010 not printing windows 7 64 bit
If this printer was installed from the network its possible the windows 8 driver was incorrectly loaded on the server or from the disk. Happens a lot. If you have access to the change driver tab under printer properties, change it to a windows seven driver. Those can be found at www.xerox.com, clicking support and drivers and then typing in the model number and clicking on driver/downloads. You can at this point either let the automated Install handle it, or cancel after it has extracted to c:\xerox and manually change the driver as mentioned above. PS and pcl make no difference, however I highly do Not recommend the global driver for this little guy.
Sep 06, 2013 | Xerox Printer Division Xerox Phaser 6010/N...
Hi i have Xerox 7760DN with both ps anc pcl enabled - there's a 68 page document getting prited everytime the printer is turned with bunch of gibbersih from startup. DO you know the resolution for
Sounds like a print job was sent to that printer using the wrong print driver. Unplug the printer from the network and see if it only prints the startup page. If so, then you need everyone to cancel the print jobs they sent to this printer. Then hook the network cable back to the printer and see if a print job can be sent to it (one that has worked in the past). I suspect someone has an old printer driver that is using this machines IP address to print to and it is confusing the Image Processor Board...
Apr 04, 2013 | Xerox Phaser 7760DN Laser Printer
Kindly, read the previous posts. I have taken some time to compose them accurately and carefully. I cannot think of any more information to submit to resolve my problem. I can't print. According to...
If everything at the printer looks fine (test prints, and no errors on the display) I would de-install and reinstall the software. The DE-install is important, DO NOT just reinstall over the top of the current installation. Also I would reboot after I removed the software and BEFORE I reinstall it. It might be overkill but it won't hurt to be through.
Sep 22, 2011 | Xerox Phaser 740 Plus Laser Printer
I have hte xerox phaser 3100mfp & when I try to scan some paper to media device it says "memory full press <stop>" what should I do? P.S. I've tried to restart the device but...
13 Memory full The machine memory is full (there are too many documents that have been received but not yet printed, or waiting to be transmitted).
Print the received documents.
Delete or transmit in immediate mode the documents waiting to be transmitted.
14 Memory full Received document memory saturated.
Jul 13, 2011 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 8560DP shows annoying 'print completion' message
Someone installed the "Printing Scout" on this computer. You may need to uninstall or check all the settings in the printer driver. I'm not really familiar with Macs but I know the 8560 inside out, upside down, and backwards.
Jun 08, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 6100 will not print
Yeah you need to replace that imaging and transfer units for it to print. That has a counter on it and once it comes up with that message it will not print anything.
NOW THE WARANING. Once you replace the unit. Everything you have sent is in the memory and will print out.
What you will want to do is once it starts printing, continue to cancel the jobs until they are all out of memory. Believe me, the jobs are there....
Oct 09, 2008 | Xerox Phaser 6100/BD Laser Printer
Not printing
Hi ,
There may be several causes for this problem.
I will tell you one by one, and you try it.
CAUSE: 1
The printer is not
receiving power.
SOLUTION:1
Check the power cord connections.
Check the power switch and the
power source.
CAUSE:2
The printer is not
selected as the
default printer.
SOLUTION:2
Select Xerox Phaser 6110
Series as your default printer.
CAUSE:3
Check the printer for
the following:
• The printer cover is
not closed.
• Paper is jammed.
• No paper is loaded.
• A toner cartridge is
not installed.
SOLUTION:3
After locating the problem, clear it.
If a printer system error occurs,
contact your service representative.
• Close the printer cover.
• Clear the paper jam.
• Load paper.
• Install the toner cartridge.
CAUSE:4
The printer may be in
manual feed mode
and out of paper.
SOLUTION:4
Check the message on the Status
Monitor program window, add paper
to the tray and press the
button on the control panel.
CAUSE:5
The connection cable
between the
computer and the
printer is not
connected properly.
SOLUTION:5
Disconnect the printer cable and
reconnect it.
CAUSE:6
between the
computer and the
printer is defective.
SOLUTION:6
If possible, attach the cable to
another computer that is working
properly and try to print a
document. You can also try using a
different printer cable.
CAUSE:7
The port setting is
incorrect.
SOLUTION:7
Check the Windows printer setting
to make sure that the print job is
sent to the correct port. If the
computer has more than one port,
make sure that the printer is
attached to the correct one.
CAUSE:8
The printer may be
configured
incorrectly.
SOLUTION:8
Check the printer properties to
ensure that all of the print settings
are correct.
If u still cant find the remedy, go for the support from XEROX,
www.office.xerox.com/printers/color-printers/phaser-6110/serv-enus.html
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | Xerox Phaser 7760/YDX Laser Printer
PRINTING ERROR
Online Repair Services For Printer Users At Low Costs Call 1- 800-956-0247
We are an authorized service center at toll free number to provide Printer Repair Customer Support services for online printer users at low costs. We have dedicated and professional team, who is very trained and experienced to repair printer rightly. Our printer technicians are highly proficient and depth knowledgeable to solve all technical errors related to printer. Our experts are simply available to help you for any type of technical error. Our online repair services are also available at your desk to solve your problems immediately.
Corporate Office:-
1680 Michigan Avenue,
Suite 700, Miami Beach, FL, 33139
USA Phone Number:- 1- 800-956-0247
http://www.printerfixit365.com/
Youtube:- https://www.youtube.com/watch?v=71cwRgd1W7M
Blog:- https://printerfixit365blog.wordpress.com/2018/03/12/how-to-use-a-printer-at-affordable-cost/
Facebook:- https://www.facebook.com/Printer-Fixit-365-1061418913976081/
Twitter:- https://twitter.com/printerfixit365
Google Plus:- https://plus.google.com/103524620603339733341
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser 6010n Laser Printer - Color - 600 X 600dpi Print - Plain Paper Print - Desktop. Phaser 6010 Clr Laser 12/15ppm 1200x1200dpi Ltr/lgl Usb/enet 110v C-lasr. 15ppm Mono/12ppm Color Print - 160 Sheets Input - Manual Duplex Print - Lcd - Fast Ethern Logo
81 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
