Question about Cakewalk Music Creator 4
When i record somethin it is fine but when hit stop recording and
Then play it back it is way to fast and high pitched
Check out what sound card you have,then make sure that your card name is sloted as you playback output
Posted on Mar 14, 2009
How get fast or slow speed when record music woice recorder
If the used recorder doesnt provide these filters from default...choose any audio editing app to play with the recorded audio file speed or pitch as u like.
Dec 14, 2017 | Audio Players & Recorders
Cassette deck high pitched noise when playing
Sometimes this is caused by the record circuit being activated due to some kind of faulty switch. At other times it's caused by a fault on the pre-amp circuit. Possibly in the power supply to it. Perhaps a faulty capacitor?
Dec 09, 2013 | Audio Players & Recorders
High pitch feedback
you are sending the signal back on itself, hit the usb to main switch to off.
Nov 12, 2013 | Peavey PV6 Mixer
I do not know how to use it, i have the manual, but i do not find it
The recorder takes 2 AAA batteries. Press Menu/Folder (on the right above the jogdial (Stop, Rewind, Fast Forward, Play)) to select the folder to add a new recorded item. (The folders are A,B,C, or S. Folder S will come up with a date and you can select another date for the recording.) Folders A, B and C can hold 100 files each; Folder S has 365 dates which can hold 15 items each.
Press and hold the Menu/Folder button for a second or longer. The Screen should show the Mode menu. Press Play and then the Fast Forward and Rewind buttons to set the recording quality. HQ is the high quality recording and will fill up the available storage on the organizer more rapidly. LP will record for the longest period.
Set the Microphone sensitivity by pressing and holding Menu/Folder. Then press the Fast Forward or Rewind button until Mic appears on the display. Then press Play and use the Fast Forward or Rewind buttons to select Low or High sensitivity. (An external mic often gives better results.)
Once you have set the folder for the next recording and the recording quality and microphone sensitivity, press Rec (center above the jogdial) to start recording. Press Stop to end the recording or Rec to pause it. (It will stop if the Pause is longer than 10 minutes.) Press Display to see how much longer you can record before using up the available storage space.
To play back a record, locate the item in the folder then press Play.
The manual for the Olympus VN-1800 is available from the Olympus support site: http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=841 . The direct link to the English version of the manual is http://www.olympusamerica.com/files/oima_cckb/VN-900_VN-1800_VN-3600_Instructions_EN.pdf .
I hope this helps.
Aug 30, 2011 | Olympus VN-1800 Digital Voice Organizer
You've recorded a track. You hit Stop. You want to capture more of the conversation in the room, so you FORGET to hit New Track, and instead push the record button. Which resets the already-recorded...
Yes, it's gone.
This is the one glaring fault with the 9600, if you select a previously-recorded track, and hit 'record', and then 'play', there's no failsafe, or 'are you sure?' prompt to remind you that there's already content within that track.
If you select the track, and ONLY hit 'record', putting the machine into record standby, but don't hit 'play' to start recording, your previous content is saved when you hit 'stop' - record standby doesn't overwrite anything.
Dec 08, 2010 | Alesis MasterLink ML-9600
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
Playback is to fast
Oh wow dude,
it sounds like your bit rate and sample rate are out of whack. You should shoot an email to tech support cuz this is gonna need some more in-depth help than i can really get into here. But check your bit depth and sample rate first. They may be out of sync
Jan 27, 2009 | Cakewalk Music Creator 4
Re: Tascam dp-02 8 track digital recorder been using for over a year no problems and having fun right up to today ... was adding a track to a song when i did a "punch -in" with the guitar (which i have...
It happens all the time to me. Only solution is to save constantly as you record because once it freezes up and says not stopped you can only unplug and plug back in then turn power on. You will lose what you were recording but nothing will be lost that you have saved.
Jan 19, 2009 | Tascam DP01 All-In-One Recording Package...
Playback is way off tempo
I had similar problem, mine played it back slower and lower pitched. http://www.cakewalk.com/Support/newfaq.asp#10
number 10 and 11 fixed my problem, hopefully it will help.
Jan 07, 2009 | Cakewalk Music Creator 4
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
Cakewalk Music Creator 4 Logo
113 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
