Question about Silver Cross Balmoral Pram Carriage Stroller
I need four replacement wheels for a toy pram
Plastic spokes with rubber tires pink or white
3 Suggested Answers
  • 12 Answers
SOURCE: wheel replacements parts fo kensington pram
To find a new wheel for the stroller might be hard but I'm positive that you can find one on the internet where you bought it I would also try ebay.
Posted on Dec 30, 2007
SOURCE: silver cross coach built pram
I am trying to get 2 16inch wheels & 20 inch wheels for a 1971 Sliver Cross Kensington
Posted on May 04, 2008
I need to replace the tires and casters on my probasics wheelchair. I am not sure what I should order and whether the tires come on the wheels ot what.
As a general rule, it is best to replace the caster as a complete assembly consisting of tire and wheel hub. Usually this is the only way to replace casters when the tire is molded on to the wheel hub. It is the best way to replace the caster since you get a tire, wheel hub and 2 new bearings.
With regard to the drive wheels on a manual wheelchair you can get just a new tire. With a plastic mag wheel and hand-rim you can sometimes get just a replacement snap-on tire to replace the existing.(Snaps on like a rubber band using tire irons). If the hand-rim, wheel, spokes, and bearings are worn or broken, you are usually better off replacing the wheel assembly. With power chairs, it is more cost effective to only replace the drive tires and use the existing wheel rims. Hope this helps.
Dec 23, 2010 | Probasics Health & Beauty
Hi, my baby's valco runabout2 tri mode pram needs the foam on the handle bar replaced & the wheel on the front has come away from the shaft & is dangerously wobbly. I purchased the pram from ebay,...
you can buy hollow foam from clack rubber shops
and the wheel assembly from a wheels and castor retailer
take the pram,/stroller in and they should be able to match it
contact the manufacturer as well as they may have spares for the unit
Aug 06, 2017 | Toys
Where can i get a rubber tires for a Peg Perego John Deere Gator HPX 12 Volt Ride on Toy?
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
Oct 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
Replacing spoke on the rear tire of a bicycle.
buy a spoke wrench and a spoke for your model bike
remove the tire, tube, and the rubber protection band on the inner wheel
feed the new spoke through the spoke's mounting hole on the hub first
now feed the spoke through the hole in the wheel. you may have to tweak the spoke somewhat to get it in place.
if the spoke is the correct one place the spokes nut to it and thread it on by hand first then use the wrench. tighten it up snug and snig the rest of your spokes with the same tesion a little at a time
Jun 30, 2010 | Cycling
Wheel replacement for older Peg Perego pram carriage
I have the same problem for a vintage 1860's Pedigree pram. Did you ever get the tires you needed?
Jul 31, 2009 | Peg Perego Elegante Stroller
Need 4 replacement wheels for an emmaljunga pram,can you tell where i can find them?
I have 8 extra Emmaljunga wheels for sale - 4 black inflatable and 4 white rubber. I would like to sell them asap! Contact me if you're interested!
Jun 25, 2009 | Emmaljunga Coronado Stroller
Wheel spinning / traction issue on toy gator
First off, keep in mind that there are reasons why they make the wheels of this slipper plastic - like reducing the risk of burning out the motor. That said, you know those rubber pedal extenders for infants (the things that come with 2 wooden blocks and a large rubber band, they 'may' be big enough to stretch around your wheels. Also have a look around for LEGO rubber tracks. There are some out there that may be large enough as well. Check here.
May 15, 2009 | Peg Perego John Deere Gator HPX Ride on...
Navy and white silvercross dolls pram bought 1980 new
I know exactly what you mean about the classic Silver Cross look but if you fit two larger diameter wheels the pram would not sit level unless one of the axles was repositioned to compensate.
Wheels have been retained by a number of methods and then hidden behind a (usually) chrome cap that must be carefully prised off. In more modern times it has become usual to combine the chrome cap with a spring retainer. It is fitted with the gentle tap of a mallet but patience is needed to remove it and no small amount of carefully applied force and even then there is about a 50% breakage. It is possible your pram used these.
Apr 18, 2017 | Baby Gear
EMMALJUNGA PRAM
I have 8 extra Emmaljunga wheels - 4 BRAND NEW black inflatable and 4 almost new white rubber. I would like to sell them. Contact me.
Jun 14, 2008 | Emmaljunga Viking Plus Stroller
Open Questions:
See all Silver Cross Balmoral Pram Carriage Stroller Questions
Silver Cross Balmoral Pram Carriage Stroller Logo
27 people viewed this question
Top Silver Cross Baby Gear Experts
ray gallant
Dorel UK
Dorel UK
Are you a Silver Cross Baby Gear Expert? Answer questions, earn points and help others
