How to fit a sunvic simmerstat 2. Type TYJ6202 (01B)
I have a Simpson Neptune stove 2U602W which needs new simmerstats.
If the connectors are in the same pattern, you can ignore the numbers and go by the position of the connectors, so top left on the old, would go to top left on the new.
You could ask the maker direct.
http://www.simpson.co.nz/SupportCentre
Sep 13, 2015 | Ovens
Replace oven element
Really need to know what type of oven it is. the element is either one of two types. It will either have a socket arrangement where the element simply plugs in or the element will be hard wired. That is to say it will have wires going from the element to the oven simmerstat. If it is a plug arrangement you will usually have to unscrew a couple of retaining screws at the back of the element where it attaches to the oven back wall to remove. If it is the latter just unscrew the wires and replace like for like on the new element. Cheers
Feb 28, 2014 | Fisher and Paykel Kitchen Ranges
Need a wiring diagram for ego simmerstat
Where can I find the wiring diagram for simmerstat regulator 48ER101C1P please?
Jul 29, 2012 | Ovens
Fisher and Paykel Paprika Oven Top Elements Full hot!!
No controller. The switch for each element (called a simmerstat) is what controls the heat. It is a common fault and will be fixed if you instal new simmerstat for each faulty element.
Mar 17, 2012 | Fisher and Paykel Ovens
I have a Simpson electric oven with stove top elements, and one of the burners will only cook at the highest level, I cant figure out how to change it, any suggestions?
You need to change the "Simmerstat", take the model number to your local electrical parts supplier/parts counter at your local stove retail shop that sells Simpson stoves and ask for one for that model, make sure you get the right one for the position as some control a single element and some control dual elements.
*** TURN OFF THE WALL SWITCH AND ENSURE NO POWER IS APPLIED TO THE STOVE BEFORE PROCEEDING ****
Remove the upper back panel of the stove. Swap wire for wire of the old simmerstat to the new one, remove the knob from the old Simmerstat, undo the nut securing the simmerstat in the oven control panel and discard, fit new one, secure, fit knob, fit back panel, turn on wall switch and test.
Some countrys/states require registered electricians perform this task on electrical appliances so you must ensure you can do this legally before you start and take the relevant safety precautions and don't electrocute yourself.
Apr 13, 2011 | Ovens
I am trying to replace a simmerstat in an old hotpoint cooker and have been supplied with an EGO 50 52076 070 as a universal replacement. The old simmerstat has terminals 'live' 'neutral' and 'load' - how...
I bought some of these simmerstats to refurb an industrial machine and faced the same issues - which terminals do what?
The parts came with a confusing wiring diagram, the terminal numbers didn't match.
The good news is that you can easily get inside this unit to see how it works without damaging it.
Release the metal front plate by gently lifting the tangs with a screwdriver then undrneath is a plastic shield which isn't glued in or anything, it just pulls out.
Here's what I found:
The bi-metal heater is connected between 2 and 4.
The bi-metal switch is between P1 and 2.
There is an auxiliary switch between 4 and P2 (P2 is the same metal strip as PILOT).
The auxiliary switch is closed when the control is 'not off'.
I also noted the short metal stub near 'TOP', in line with 2.
It is in fact the same metal strip as 2 so should be treated with respect i.e. it has mains voltage on it.
For my application, I wired:
Live in to P1
Neutral in to 4
Load powered from 2, returning to Neutral
Pilot Light from P1 to P2 (observe that the pilot wiring is a bit scary because it has a switched neutral).
Dec 22, 2010 | Ovens
Hi there can you tell me how to set my sunvic 207 XLS as it was installed and I was not given the instructions
Use a non-metallic pointed tool on the reset button, or go to the sunvic website for pdf manuals.
Sep 25, 2010 | Heating & Cooling
I have a belling cooker switch that has had 3 contacts welded together, i have ordered a new switch but where can i find a wiring diagram to check the conecction for the new switch
have a belling 862 and the grill switch will not regulate can anyone tell me the type of simmerstat that is required?
Jan 15, 2009 | Kitchen Ranges
Heating & Cooling Logo
337 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
