Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Can I install on a 20 amp circuit with a 15 amp GFCI plug? The unit says 120 v 6 amp max
  • Malibu Master
  • 5,245 Answers
Jan 2013
1) Yes. With 6 amps.
It is not purely code, but generally not dangerous.
Most household outlets and switches sold at home center are actually rated 15 amp, and should be on a 15 amp breaker. just don't overload.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
2) However if you are running close-to or higher amps than 15 amps, such as space heater (volts x amps = watts), then I would suggest installing 20 amp arc-fault breaker, and protect whole circuit.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
3) Add comment and say what you do.
Posted on Jan 23, 2013
Installation: Electrical Requirements
13Mb product manual is a big download ... electrical info page 13:
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-gas-water-heater.pdf
http://waterheatertimer.org/pdf/AO-Smith-Cyclone-electrical-connection.pdf
Recommended both water heaters require dedicated single-phase 15 amp 120Volt line with correct polarity. This is 14 gauge wire and 15 amp breaker for each unit.
I would put both water heaters on surge protection and GFCI. Most water heaters are not protected from surge, and manual says line noise can affect operation of water heater.
Your local code would say if GFCI is required. Install GFCI breaker in main panel if required.
Install inline surge protector: Or add main breaker box protection.
http://www.amazon.com/dp/B003AU0Z48/?tag=waterheaterti-20
AO Smith service handbooks:
http://www.hotwater.com/resources/product-literature/service-handbooks/
Add a comment and say what you discover
May 17, 2013 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
Is a Hampton Bay HBD240A window A/C 120v or 240v?
I have never seen a 240-volt window A/C unit for the U.S. market. So, my guess is it's 120 volt.
The best way to verify this is to read the name-plate on the unit.
Another way is to look at the plug on the unit's cord. There are at least three types of plugs :: 120 volt, 15 amp; 120 volt 20 amp; and 220 volt. 120 volt 15-amp will fit a standard household wall outlet. The 120 volt 20 amp plug is similar to a 120 volt 15 amp, but will not plug inot a standard household outlet. The 220 volt plug is altoghether different.
Charlie
Jan 08, 2011 | Heating & Cooling
I have a 15 amp air conditioner, with afci plug on a dedicated line, on a 20 amp breaker. Why does it nuisance trip, and not allow me to reset it, is it because of the 20 amp breaker? DRJ
It's definitely not related to the 20 Amp breaker. You do mean GFCI, right? The kind built into the end of the cord on the air conditioner, right? The GFCI is either detecting a ground fault (which means it's doing it's job and there is something wrong with the cord or the unit) or you have a bad GFCI. If the GFCI is in the wall receptacle, that could be a different story.
Jun 24, 2010 | Solar 15 Amp Murray Afci Circuit Breaker
We have a circuit fed by a sq. d QOB120GFI on that circuit we have individual gfci receptacles is this a problem?
yes, you should not feed a ground fault receptacle with another gfci. You will have problems with it not resetting when you have too many in line. You should only have one in the circuit at the line.
Jun 22, 2010 | Square D Qo 120 Volt 15 Amp Gfci Gfi...
I need the electrical volt & amp requirements and location of electrical outlet
Assuming this is for wiring a new outlet....
120 volt 15 amp min to 20 amp max plant the plug right behind the fridge opening. It is a wise Idea to make this a dedicated circuit as well.
Hope this helps!
Jun 17, 2010 | Refrigerators
15 AMP versus 20 AMP outlet plug
The circuit is protected by the 15 amp breaker. That's what matters, the wire size and the breaker feeding it. It's OK to have a 20 amp recepticle fed by a 15 amp breaker.
Sep 11, 2009 | Electrical Supplies
Hooking up a Hot tub
Everything above tells me this is 120V unit...if thats the case a single pole breaker is sufficient. Also by what you have written, a 15 amp breaker should suffice.
Jun 22, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
GFI on cord trips out.
Probable cause is a single pole gfi opposed to a double pole gfi.
* Do not use a single pole GFCI ON A MULTI WIRE CIRCUIT, IT WILL NUISANCE TRIP IMMEDIATELY
Use a two pole GFCI circuit breaker on such circuits.
May 20, 2009 | LG LWHD1800R Wall/Window Air Conditioner
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
66 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
