Question about Haier XQG50-QF80 Front Load Washer
Spinning but clothes are still very wet ,
We have an haier 1400 spin machine,after spin clothes are still dripping wet and the letters unb appear on display,can u help
    Problem Solver:
  • 5 Answers
Unb means unbalanced i had the same problem and i called comet where i got it from and they replaced the chip board and ever since then its been fine i hope this helps you
Posted on May 15, 2009
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Apr 22, 2016 | Tricity Bendix AW1000W Front Load Washer
Error code Unb: After the last rinse finishes, spinning fails completely due to unbalanced of the laundry (What does this mean) and How do I clear the error. Machine does not spin the clothes.Every thing...
I have had the same problem with the same model and rang up the help line to be told that the machine cannot sense the clothes in the drum. I tilted the machine forward and this worked for a while, sometimes i have to unplug at the wall so there is no electricity flowing through the machine for an hour and it resets itself,. Its not adequate but it works.
Sep 02, 2010 | Haier Washing Machines
Haier xqg50 will not dry; It runs the full wash cycle, and will actually run the dry cycle, but the clothes come out comletely soaked. Ran the full 120 minute dry cycle three times, and the clothes were...
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 11, 2010 | Haier XQG50-11 Front Load Washer / Dryer
Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Feb 17, 2009 | Haier HWD1000
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
What does unb at end of wasn after it says end??
unbalanced - means it didnt spin properly due to clothes being unbalanced. Its supposed to stop the machine damaging itself - but its just a pain. Need to fill the machine with a full load to avoid this. Dont suppose your machine's a Haier??
Jan 03, 2009 | Washing Machines
My Haier HW-C1460TVE-U washing machine was installed this morning did the empty cycle first then did a load of towels worked perfectly did another wash Err code Unb came up. Got sprit level and checked...
Have been to one of these machines today. UNB will still show even if the machine is empty. I think the feedback amplifier on the main PCB is at fault. If I have any luck with it I'll post another message
Jun 29, 2008 | Washing Machines
Haier front loader 1400 spin
check to see that pump is not blocked stopping water getting away quick enough
Mar 16, 2008 | Haier XQ8M22-C PORTABLE TOP LOAD WASHER
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Haier XQG50-QF80 Front Load Washer Logo
531 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
