Question about Antari Z-1200 Ii Fog Machine With Remote Z1200 2
Z1200 main pcb - Antari Z-1200 Ii Fog Machine With Remote Z1200 2
No power in Mackie TH-15A
i) I assume the fuse you mentioned was in the mains plug - did you also check the fuse in the TH15A mains input socket? This is accessed by pulling out the tab in the bottom section of the socket (below the centre pin). This is a 3.15Amp antisurge fuse, 20mm type.
ii) If this fuse has blown, then replace it & all may be well ...... but if it blows again, then move to step iii).
iii) With mains disconnected, remove rear panel (outer screws) & check the power supply PCB for damaged components, especially R111 & R112 (100ohms). If the latter are burnt or open circuited, then the amplifier module may have blown.
regards, Dave
Aug 20, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Why power cutting out on yamaha-p95
Hi, This could be for a number of reasons the most common causes are :
1) Socket where mains adaptor is plugged in becomes loose on the PCB and will need to be replaced / repaired
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17018
2) The power supply unit fails and needs to be replaced. You should only use the correct power supply for your instrument.
Jun 24, 2014 | Yamaha P-95 P95 DIGITAL PIANO BLACK
My Privia px200 won't turn on, what is the problem
First get a new 12V DC power supply (AC Adaptor model AD-12) to test.
Otherwise it needs repair by Casio technician. Main PCB board may need to be replaced.
May 29, 2014 | Casio PX200 Privia Digital Piano with...
Swr 750x has a short
The 12ax7 preamp tubes will act just like that when they get old, in fact, this would be my 1st check before I go any further, other than ventilation and heat .Make sure you are using the right impedence output jack to match your cabinet. Make sure the effects mix level is not overriding your guitar signal. Also, make sure that your signal is not being clipped showing the red led's. Also, the variable limiter control, if turned up very high, will do that to a point similar to a compressor/limiter. I would definitely check the tubes for the crackling sound could be just that.
Mar 11, 2013 | SWR 750X Pro Series Bass Amplifier Head...
When I press the keys any harder than a light touch on my Yamaha, the entire piano keyboard turns off and on again. Is there a wire loose or something? How do I fix it? It's my friend's Yamaha
Is the unit operated directly from the mains or via a mains adaptor (transformer) If it is the later then my guess is that the socket owhere you plug the power adaptor in is loose. They have a habit of breaking away from the circuit board. When you then move the keyboard it breaks the connection . You can test this theory by turning it on, looking at display or light that is on, move the plug and see if it cuts out. If it does the fault is here. Replace the socket and if needed repair pcb as pads tend to break away from board.
If it is mains operated or power socket is OK then it could be loose cables or a break on the PCB. The socket option is the more likely.
If you need more specific info on your keyboard please state make and model and request further info under this topic.
Jan 23, 2013 | Music
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
Apr 26, 2012 | Line 6 Music
Ive just bought a faulty Br Micro and have been told that there is a problem with the mains PCB board due to the wrond adaptor being used. How can I fix this? is it a soldering issue or do I need to get a...
It is impossible for us to know what damage may have been done... Repair on this would likely involve changing of surface mounted components which takes a lot of skill. This is probably going to require repair at the factory.
Sep 14, 2011 | Boss Micro BR Digital Recorder
Not getting started even after connecting to power supply
Make sure that the power comes into the board from the adapter unit. So check the voltage to the keyboard.
If not present check adapter for failure ;If SMPS type check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
If otherwise you must open to check the power to the incoming board, the regulator , the supply to the main switch and the power to the main board, the synthesizer section/processing board. remove and plug back all connections, if not there are errors in the PCB.
Sep 29, 2010 | Yamaha Full-Size Keyboard
I HAVE A Yamaha PSR 260. About 8 years old. Recently it became defective.: Only the display lights up . No sound. No response to any button. When volume control is turned, I can hear the faint rustle on...
This MAY be due to a key contact or button that is STUCK "on".
Often this will freeze the controller.
Make sure power adapter is the correct one... underpowered or incorrect ones cause trouble.
Mar 20, 2010 | Yamaha Music
On the ZR-76 keyboard, no output on main or aux output jacks ok on headphone
Ensoniq zr-76 no output signal on the main and aux, but i have output on headphone jack?
Oct 15, 2008 | Music
Antari Z-1200 Ii Fog Machine With Remote Z1200 2 Logo
35 people viewed this question
Top Antari Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Antari Music Expert? Answer questions, earn points and help others
