Question about GE GTWN5050MWS Washer
WHERE IS THE LID SWITCH ON GE WASHER - GE GTWN5050MWS Washer
buffalonyman
  • 1865 Answers
SOURCE: GE washer doesn't spin or agitate has new timer
Bad motor?
Posted on Apr 15, 2009
  • 326 Answers
SOURCE: Washer will agitate but will not spin, could it ge lid switch ??
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on May 06, 2009
  • 129 Answers
SOURCE: GE Washer will not spin...replaced lid
ck power plug behind control board ,has 1 year warranty, could be motor, or control board
Posted on Feb 04, 2010
  • 31 Answers
SOURCE: how to test bad and good lid switch for washer ge top lpad
Yes the switch is bad.
Posted on Nov 29, 2011
TheMobilian
  • 8220 Answers
SOURCE: ge washer whre5260e1 wont spin all the time
easy fix.
replace the motor:
Video
Service guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 06, 2012
Ge washer not draining or spinning
Im 99.9% sure its the lid switch. You can bypass the lid switch but for safety reasons I recommend replacing it.
Oct 27, 2012 | GE Washing Machines
Will not spin or agitate
You should check the lid switch.When lid is shut.contacts should be made.I expect the switch is open
Oct 21, 2009 | GE WJSR2070B Top Load Washer
Hotpoint washer lid switch can you show me the lid switch
Smewhere around the rim of the opening in the washer you should see a little tab, this is the switch arm that the lid contacts when closed to allow the washer to run, it should be free to move
Aug 22, 2009 | GE WBSR3140DW Top Load Washer
My washer will not agitate after filling with water...
is the lid closed? if it is the it is the lid close safety switch you can by pass the switch but i would replace it if u do bypass unplug the machine its a safety thing. Tom
Jun 29, 2009 | GE WBSR3140DW Top Load Washer
My GE WDSR2080D washer won't spin or drain.
The crappy designed mexicanical lid switch device has faile, jump it out. Remove the front panel and then you can get the top off to access this problematic lid switch.
Jun 14, 2009 | GE WDSR2080D Top Load Washer
GE WSJR4160DOWN
You don't have to remove the washer top. Use a putty knife to push the tabs in on the left and right side, about two inches from the sides, at the top seam of the front panel. Front panel pulls forward and lifts off bottom pegs. Lid switch has a tab you need to push toward the center of the switch (its on the back side of the switch) which will allow the switch to push up. twist the switch and pass it back down through the washer top.
Oct 11, 2008 | GE WBSR3140DW Top Load Washer
The start pause button will not work on my GE washer so washer will not come on
f the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Aug 12, 2008 | GE Washing Machines
No spin
lid switch sounds like some ge had a plunger type switch operation ck for broken pin on lid that pushes switch lever down ..others had a magnetic type switch magnet on lid front right corner that closed switch on cabinet front corner
Jul 31, 2008 | GE WBSR3140DW Top Load Washer
GE GTWN5050MWS Washer Logo
18 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
