Question about Apple Mighty MA086LL/A Mouse
How do you change batteries in mouse #A1152
Message says to change mouse batteries, how do I do that?
  • joyce leuckel Jan 22, 2013
    how do I change batteries in mouse?
Changed batteries in mouse and still getting message "battery low etc"
The mouse has a built in capacitor which provides power to run your mouse. When a capacitor gets older they get weaker and will keep the battery low light on constantly. Capacitors are made for storing voltage so the circuitry receives the proper power as needed. I mentioned when they get old the capacitor will not hold the proper voltage as needed. I would just replace the mouse sooner than later for eventually it will plain quit working someday soon
Jul 03, 2010 | Computers & Internet
"Connection lost"
Normal 0 First make sure the batteries are good in the mouse. Then do the following.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Dec 07, 2009 | Apple Mighty MA086LL/A Mouse
Changed the batteries now the mouse doesn't work
Hi there.
Underneath the mouse there should be a small button which is the connect button, press that and also the button on the docking station if there is one.
Also check to make sure the batteries are in the right way as its an easy mistake to make.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | Logitech MX700 Cordless Optical Mouse
Lost signal on Microsoft 4000 wireless keyboard & mouse
you have a resset onder the mousse, change the battery , and reinstall the driver
Dec 31, 2008 | Microsoft Natural Ergonomic 4000
Battery Message
Method 1: Try different ports. Method 2: Install fresh batteries. Method 3: Resynchronize your device to the receiver. Method 4: Install the latest software from this website: http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
and Method 5: Clean the mouse lens.
Oct 21, 2008 | Microsoft Wireless Laser Mouse 5000
Not working properly
Are the batteries good in the mouse?
If they are try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
May 28, 2008 | Belkin Mini Wireless Optical Mouse...
My keyboard and mouse
Underneath the keyboard there should be a series of number . this should be the id.
let me know if this helps.
May 08, 2008 | Computers & Internet
Warning: receiver channel changed - wireless keyboard and mouse
I contacted Gaeway Support. They quickly answered and suggested that I change the batteries in my wireless mouse and/or keyboard. I did. It was the mouse. As soon as the new batteries were in, the popup went away and stayed away.
Jan 07, 2007 | Gateway 2520915 Keyboard
Apple Mighty MA086LL/A Mouse Logo
139 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
