Question about Kenwood Kdc-152 Car Stereo In Dash Cd Player W Radio Receiver Head Unit
Postive and negitive wires - Kenwood Kdc-152 Car Stereo In Dash Cd Player W Radio Receiver Head Unit
    President:
  • 720 Answers
Yellow wire - goes to constant 12v
Red wire - goes to Ignition switch
Black wire - goes to earth (screws into metal bracket behind dash)
Posted on Mar 04, 2013
How to determine the postive and negitive wires for the Targus APV10US1 100W Slim Line Mobile Inverter 150Watt Power Supply
With colour coded wires, red is + and black is - . On the two pole connectors part the + is the inner one and - is the outer node surrounding it. If you're not sure take the connector off and check which wire goes where. Red is always +. Better yet, use a DC tester or make your own using a LED of sufficient current rating (12V in your case). With all diodes current only goes one way from + to -, so it'll emit light if it's connected properly and not, if it's not.
Apr 19, 2012 | Targus APV10US1 100W Slim Line Mobile...
Adding heated handgrips to HD xl 1200 C CUSTOM SPORT.WHERE DO I CONNECT LIVE WIRE.
Connect red wire to postive post on battery and black wire to negite side of battery MOPAR KENNY
May 22, 2011 | Harley Davidson XL 1200 C Sportster Custom...
When i hook the postive/negitive and remote wire my amp whines everthing is hooked up correctly but i get no output
there are coils inside the amp the power it an ur output input could be burned out . u can bring it to a pro to fix it . it would cost no more then $100 to fix it . i hope this was helpfull
Feb 22, 2011 | MTX Thunder 6500D Car Audio Amplifier
1999 escort zx2 which battery cable is postive an negitive both are black
Hi, the negative one will connect directly to the engine block. The positive one will connect either to the starter or to the relay box by the battery.
Feb 13, 2011 | 1999 Ford Escort
What size socket to remove 2002 olds alero battery
1/2 inch or 10 mm try until you find the right one but do it on the negitive side no postive side postive side is red negitive side is ground good luck
Dec 03, 2010 | 2002 Oldsmobile Alero
Is the black wire negitive and white wire postive
The Black wire is the Hot or positive wire and the White wire is the nuetral or negative wire.
The green wire gets hooked to the frame or any metal part of the dishwasher...usually there is a green screw inside the little box where the wires hook up
Heatman101
Apr 15, 2010 | Bosch SHU9925UC Built-in Dishwasher
Replaced AC Condenser and Evacuated System.. Holds negative pressure but when adding the freon after the oil all the freon doesnt seem to empty out of the can. And noticed that the Compressor hasnt...
When you add the freon turn the can upside down and it will push the oil and freon out of the can. If you have it up it sends freon but no oil.
You also may need more freon before the compressor will kick in.
Jul 19, 2009 | Dodge Dakota Cars & Trucks
FOR MARANTZ SR5000 RECEIVER
for the RCA cables there color coated RED and WHITE, for example ur hooking up a cdplayer 2 ur unit, cd player output, Red = Right, White = left
the cables go to the cd input on the back of the unit, same as for selections DVD,AUX,an so on some mite have a yellow witch would be Video
and for the speakers, some are black an red, some are clear an has a white strip that would be the negitive wire, red is postive black is negitive those are the color codes for the terminal on the speaker outputs, hope thats what ur asking
hope it helps
Feb 12, 2009 | Marantz SR-5000
Help!
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
Dec 04, 2008 | 2003 Volkswagen Golf
Kenwood Kdc-152 Car Stereo In Dash Cd Player W Radio Receiver Head Unit Logo
42 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
