Question about Daewoo Refrigerators
Our Daewoo NoFrost MultiFlow fridge-freezer has just stopped working - seems to have lost electric power - any ideas, please?
This appliance is a "back-up" to the main fr/fr in the house - this one is in the garage. Both fridge and freezer are warm - all food has defrosted and is soft to the touch - must have happened a few days ago. The fan behind panel in freezer does not spin - the light, unfortunately, blew some time ago so can't tell you if it would light up or not. Fuse checks OK. Seems that electrics have packed up. Wondered if the cold spell (minus 3 at night over last four days) has affected anything - frozen up something inside perhaps. Have just put a heater in the garage (fr/fr switched off - doors open) to see what happens over night. If anyone can help it would be much appreciated, please - as a pensioner I'm reluctant to spend lots of money in calling out expensive experts, but guess I might have to without your help. Mike
  • Mike Veasey Jan 24, 2013
    Although I'm told 15 "experts" had viewed my request, above, I have not received any expert advice. However, I seem to have solved my own problem! By warming-up the garage over a 24 hour period, and then switching the fr/fr back on, the unit started working again. So, should anybody have a similar problem in the future ..... try this solution.
SOURCE: Zanussi ZX99/5SI
I had this problem with my ZX99. In my case it was caused by faulty temp sensors not making the defrost system kick into place. The defrost cycle works by heating an element for every week or so for a few minutes.
Posted on Aug 01, 2007
SOURCE: My Beaumark Bottom Freezer Refrigerator Doesn't Work
problem is probably that the evaporator is frozen up preventing circulation of air and the fan is jammed with ice.
remove the back panel inside the freezer. melt off the ice with a hairdryer taking care not to heat up any stats mounted on the pipework.
appliance will now work but this is a temporary repair. you must find out the cause of the ice build-up ie why not defrosting.
for starters, check the defrost heater and the thermal cut-out inseries with it.
let me know how you get on and what you find. make sure the fan is free to rotate.
tresilla
Posted on Nov 06, 2008
  • 1122 Answers
SOURCE: Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Posted on Nov 30, 2008
  • 31 Answers
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
SOURCE: GS6NBEXRSOO model whirlpool gold 2005.
My freezer is working but my freige is not working what should I do
Posted on May 01, 2011
Whirlpool fridge/freezer LCD replacement
What is the model number listed inside the refrigerator section?
Nov 17, 2012 | Refrigerators
Daewoo No frost multiflow fridge freezer. Freezer works fine. Light comes on in fridge but it is not getting cold. What can we do? Is it broken or is there a magic switch somewhere? many thanks
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | Daewoo Refrigerators
Hi, During the recent Brisbane floods, my Daewoo fridge/freezer was turned off for 8days, as we had no power. Since power has been resumed, the freezer does NOT freeze the top 3 shelves in the...
You poor fridge has developed a refrigerant leak.
While the fridge was working before the flood the refrigerant was cold and din't escape. While it was off the metal expanded, opened up the leak and let most of the refrigerant escape.
You will need an ARCTICK approved appliance repairer to fix that problem.
http://www.lookforthetick.com.au/business-search/
Mar 24, 2011 | Daewoo Refrigerators
Got a daewoo upright fridge freezer no frost multiflow system,light is on in fridge compartment but everything else as stopped working,everything has defrosted can you help please
Just try to check wethere the compressor is working or not. but if working. maybe theres a leaking in the the tube. causing no freon inside.you need to reprocess your freezer .
Jun 30, 2010 | Freezers
FREEZER COLD FRIDGE WARM
for static cooled appliance If the appliance runs for a very long time without having any problems and this suddenly happens it can be that a gas leakeage in the cooling circuit.circuit has to be checked for rust and corrosion especially at the welding points.
If nofrost appliance with one evaporator flap can be malfunctioned or ice accumulation block the flap.Plug off the appliance and wait for 12 hrs with opened doors.Restart.
Jun 30, 2009 | Refrigerators
Refrigerators Logo
63 people viewed this question
Top Daewoo Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
