Question about Mission 70ASA Speaker
Speaker suddenly emits very loud noise. Have to unplug it.
I have used this sub woofer for many years. It is always plugged in to 120v but suddenly it gave out this ear splitting noise!
  • Ken Hobden Jan 24, 2013
    Has anybody else experienced this? The low frequency sound like a very loud rumble cannot be tolerated for even a second. When it happened it could be heard all over the house.
Bad capacitor(s). Happened to mine too. Opened it up to find 2 completely blown apart, and 1 bulging. Relatively cheap and easy to replace.
Posted on Oct 05, 2014
  • Allan
    Allan Oct 15, 2014
    Went through with the repair that I thought was easy. Turns out the module (silver aluminum sealed block on the circuit board) was the cause and is non-replaceable due to being a poor design to begin with. A whole new class D plate amplifier is the most cost-effective solution.
How do I stop right satellite speaker from emitting a loud buzz once I plus it in to the sub woofer?
Your speaker may be blown. It doesn't have to be fiscally blown maybe you just burned or disaligned the coil/s try a different sub or check your amp it could be blown. Defective parts in an amp could emit weird sounds to your sub.
Jan 07, 2015 | Altec Lansing VS4621 Octane 7 2.1-Channel...
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
Sub woofer buzzes all the time, do I have to replace the speaker or can this be repaired?
ur sub wont buzz due to bad speaker. either u have a faulty preamp or power amp. yes it can be repaired and will not cost much. if it is loud and annoying, get it repaired. sometimes subs emit low hum when powered up. this is the way the are desinged.
Apr 13, 2010 | Kenwood SW-306 Speaker
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Nov 18, 2009 | Bose Acoustimass 15 System
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
MT HT-TX52 WORKED FOR A COUPLE OF MONTHS, THEN THE SUB WOOFER WOULD MAKE A VERY LOUD CRACKELING NOISE ALL OF A SUDDEN, BUT ONLY ONCE IN A WHILE, SO I UNPLUGGED IT AND JUST RAN THE OTHER 4 SPEAKERS. WORKED...
Maybe a capacitor in the amp section is making this problem.The only way to find out is to check receiver in service and find which capacitor is bad...but this is not so easy
Apr 18, 2009 | Samson Audio Players & Recorders
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Mission 70ASA Speaker Logo
188 people viewed this question
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Steve K
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
