Question about Emerson EM2116 Corded Phone
Hear nothing in headset
Phone will dial and others can hear but no sound coming from speaker in headset
Can not hear dial tone or hear caller / can hear on speaker call
Most likely that it is the speaker on the handheld part of the phone. Your sound comes from the base itself when you put your current connection on Speaker-Call. So if you cannot hear the dial tone OR the person on the other end unless on "speaker" it's just the handheld and I believe there are places online you can purchase JUST that part if needed.
Oct 19, 2014 | AT&T ATT-1855 Corded Phone
On my new Plantronics S12 Headset System, I hear a dial-tone (through the headset) when I press the headset button, but when I remove the phone and begin dialing nothing happens. I also tried a test call...
Unfortunately, the phone does matter. The S12 is designed to work with office style phones where the handset is just the mouthpiece, all other features located on the base. My suggestion is to get a phone of that style (you can find inexpensive ones at Wally world) and connect the headset following the instructions on this link for the Plantronics S12.
Good luck from Headsets Direct!
Jun 10, 2011 | Plantronics S12 Headset
Can't make a call do to no sound everything else works but, no sound. I plugged earphones in to listen to music and when I unplugged it I know longer could hear phone calls or when I dial the phone.
Mark, the issue with your phone is with the speaker. This has been confirmed by you when you say the there was sound produced when you used earphones.
You have to get your speaker fixed. Get it done at a local repeir store aroud you.
But in the meantime you could use the earphones for your calls so you can hear them.
But you may still have an issue- hearing your in coming calls- so if you can get a bluetooth headset, that you can hang around your ears, you would hear the calls coming in.
I hope that was helpful to you.
Have a lovely day.
May 27, 2011 | LG CHOCOLATE VX8500 Cellular Phone
Earpiece not working after hooking it up with a bluetooth speaker
Go to Bluetooth settings and turn on Bluetooth.
The paired devices will be shown.
Delete paired device or unpair device .
This should solve the issue .
Since the mobile is paired with the Bluetooth speaker every time a call comes in the phone automatically connects to the Bluetooth speaker.
Switching off the Bluetooth speaker may also work.
Mar 28, 2017 | Motorola Mobility ROKR E8 Cellular Phone
No more sound from speaker
I had a similar issue on mine. The easy fix was to insert a headset jack and pull it out quickly. I think something got stuck that turns off the speaker after I put the headset in the jack once. If this is the problem, I think you should also see a headset icon when making calls, even though no headset is attached.
Jun 15, 2007 | Sprint Vision PPC-6700 Smartphone
Emerson EM2116 Corded Phone Logo
23 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
