Question about Tascam DA-30MKII
Reset tascam da-30 mk
Tape transport repaired now error message
4 Suggested Answers
mrwtech
  • 59 Answers
SOURCE: tascam da30
www.datrecorders.co.uk/da30.pmp has a pdf version you can download for a fee.
Posted on Sep 10, 2008
caroldon
  • 17130 Answers
SOURCE: TASCAM DA-30 tape transport error
When you use any cleaner or lubricant it must be only for the moving part and must never stray into the transport section. Also what is required if there is any frictio is to dry wipe and set. Now when you lubricant got sprread into the head, the oil will act as a great adhesive at higher speed and got the tape entagled. So please wipe dry all the oil of the headd and do nto damage the head with the wipe touching the delicate ferrite heads in the slot, DO NOT TOUCH THIS SECTION but with an even paper with soft brushes. Now check you reel drive and see if there is dirrt lodged in clean and reset., put the set on for regaining lost values as many electronics capacitors may have lost value by drying. If the tape up does not move it is a mechanical problem and you must check for the drive and the friction wheel. If however the reel works and the count does not happen and you get the error , then your reel sensor is faulty. Check these points and confirm, Hope this advice helps, Good day.
Posted on Jul 26, 2010
  • 357 Answers
SOURCE: where can I get tapes
You need what are called "DAT TAPES". Just like Blank analogue audio cassettes they come in a range of lengths fro 15min to 180min. You'd be better off to use something like a 60 or 90min IMHO. Dat tapes can be purchased from places like "studio spares" or any other PRO media supplier. They can be quite pricey. I tend to buy mine in bulk on ebay.
Before you ask, not there are not different tapes for different machines, but the btands do vary. I use either HHB or AMPEX. DO NOT USE COMEPUTER DATA BACK UP CARTRIDGES as a cheap alternataive.....they are different and end up giving you a lot of loss and errors over the years...sometimes instantly (Tale it from experience!)
Best Of Luck
Posted on Sep 08, 2010
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Tascam DA88 has error light and wont play tape or show time code
These are expensive to repair and not many people are repairing them. Probably a transport issue and that might be all there is.
If you look on E bay they are selling cheap.
Feb 16, 2015 | Tascam Audio Players & Recorders
Tascam 122 mk III error code
The Tascan 122 Mk III does not have a computer in it to give error codes. I suspect that you have a power supply issue but I can only help you if I see the unit. I am in the Chicago area and run a shop for fixing these decks. I have been doing it for 40 years and have worked at the Teac Factory Service in IL.
skywavebe@sbcglobal.net if you need my help.
The symptoms are recognized as a cracked transport gear that is resolved by a new gear and a transport cleaning and new grease put in. I have done about 6 of them as this is described. I have parts in stock.
Sep 06, 2012 | Tascam 122MKIII Single Dual Cassette Deck
My TASCAM DA-20 Mk II DAT doesn't play back any of my tapes. It still appears to record OK, but there is no level meter or sound or track finding when playing back, though the tape seems to be run
Hi Julian,
There is a lot that can go wrong with these miniature helical scan systems. When I had units like that I packed them off to Russ at New Jersey Factory Service and they were restored. I am not sure about parts like drums at this point but Russ is your best chance to get it working again. He has corrected CDRW and DAT as well as just about anything Tascam makes and he even fixed some Sony units too. I know him as the counterpart to the Chicago Factory Service facility when it was open. He was the Manager in New Jersey then.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Wed 8-4 Thurs 8-3(July-Aug) Closed Fri Sat by appt.
Aug 23, 2012 | Tascam Audio Players & Recorders
Jul 23, 2010 | Tascam DA-30MKII
I have a Tascam DA-30 which ejects the tape
Many different things could sause a problem, belts, mode switch, capacitors in capstan or head motor drive circuit. Hard to say what exactly is wrong with the machine without looking at it.
Dec 03, 2009 | Tascam Audio Players & Recorders
Tascam DA30 Mk1 drawer and noise problems
HI...
There are 2 belts in the mechanism that would need replacing.
I've fixed 2 of these.
There's a very small belt on the underside of the tape drive assembly
1.55 inch belt x 0.039
www.studiosoundelectronics.com # SBO1.55
Dont remember the other
Jan 21, 2009 | Tascam DA-30MKII
Need a tec to repair
I can help you if you are in Queensland Australia. :)
Jan 19, 2008 | Tascam 122MKIII Single Dual Cassette Deck
NEED TO FIND A REPAIR SHOP YEP I NEED A FIXYA
I'm in Vermont and have 25+ years into it and good references
painintheamp@yahoo.com
Error 01
Error code 01:
what to do:
open the tray, power down the unit, remove the top cover, remove the transport
(4 screws and a few conectors... I think there's a long 'transport load spring' also...)
then turn the transport over.
Looking at the bottom of the transport, there's a small, -no, make that tiny- black rubber drive belt
which goed from a very small pulley to a rather larger pulley directly next to it...
That's the one. Buy more than one replacement (they're only a buck or two) and put a new one on.
-then take the spare, and place it in a baggie and tape the baggie up inside the lid of the DA-30MkII...
Put some sort of friendly note in there for the next time the new owner of the machine needs to replace the belt.
Oct 29, 2007 | Tascam DA-30MKII
Electronics - Others Logo
107 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Computer Links
rjivaro
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
