Zyxel P-660RU-T1 ADSL Ethernet/USB Router over POTS - 1 x ADSLoPOTS WAN, 1 x 10/100Base-TX LAN, 1 x ... Logo
Posted on Jan 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows Millenium can't connect my Router ADSL
My Windows Millenium can't connect to my Router ADSL, even it can't detect my ethernet connection. What can I do?
J John
Level 2:
Sergeant:
  • Expert 299 Answers
  • Posted on Jan 30, 2009
J John
Expert
Level 2:
Sergeant:
Answers
299
Questions
Helped
41775
Points
767
Please make it more clear your question.
1) Are you able to modify your network connection at control panel. or
2) Type at command prompt c:\ipconfig and check what ip it is showing.
Wt8951nd
Power cord
RJ-11 telephone cable coming from a splitter or the extn. line of your landline phone.
Ethernet cable coming from your Desktop/Laptop connecting RJ-45 port
Most standard ADSL modems have four/five lights in the front :
Power light to indicate electric power to the modem.
ADSL light indicates the status of ADSL sync. When the modem is synchronized with the ADSL line card at the other end of the circuit/loop, the DSL light will be steady green.
LAN light will glow steady green when the modem detects a successful link to a computer or router ethernet port.
ACT i.c. Activity light glows when the modem is sending and/or receiving data on the lan and wan. It will vary between very slow to fast flashing and steady green to indicate lan/wan traffic.
for more help visit CBR Tech Solutions
I want to install ADSL2/2 + modem with 4 port ethernet router, along with Xtreme N dual band gigabit router. My OS is Windows 7. I tried to inserting the IP address but this had no effect. Do I need new...
Hello there,
When you ask questions, you have to tell the exact model. When you say you want to install it, do you mean configure the ADSL connection and Wireless LAN? If so, you have to configure the ADSL connection first. You have to get the settings from your ISP. Usually the default address for D-Link routers is 192.168.0.1. You would also want to check the user manual.
You do not need the drivers. You are going to connect it via ethernet cable. And then you can configure from there. Once ADSL connection is working, you can now connect your Gigabit router to one of the ports on your ADSL 2+ gateway.
1helpful
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
4helpful
Linux 5 is not detecting my broadband modem
The connecting to internet is very easy in linux .
There are many steps but i am saying simple one
Initially configure the adsl router with ppoe over ethernet and enable dhcp address option.
Next plug the ethernet cable from router to the inteface of lan card.
Boot the redhat machine.
In the system-->Administration-->network options check whether lan card is detected and active .
If the lan card is not active activate and save
In lan card select option assign assig ip automatically
check whether ip is assigned by using command ifconfig .
1helpful
Zyxel Prestige 660RU Adsl 2+ Ethernet USB Router drops my dsl connection after 5 minutes of usage. Sometimes it does not connect at all. I tried restarting everytime it does it. Even unplugging it. The...
First of all, please chk if this happens without the router. If it does, then talk to your ISP . Else, I would suggest you check if you can upgrade teh firmware of your router. The router's website, should be able to give you directions on that
Hope this helps
Thanks
Ranjit
Router not connecting with adsl modem wirelessly
re-set it and re-configure it ur router then you get it
2answers
Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
No access to internet via wireless or ethernet
Check ADSL is active and connectted on the router.
Use webmanagement link the link below.
http://192.168.0.1
username: admin
password: admin
If the above details does not allow you to connect, check under the router for correct details.
Top Zyxel Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
