Question about Ricoh Aficio 1027 All-In-One Laser Printer
Sc542 service code
  • Ricoh Master
  • 1,294 Answers
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Posted on Feb 10, 2013
Hi;
Please seedling method and reset the copier Rykvafyshv SC546 error 2035 when, as here.
Thanks
Posted on Feb 11, 2013
Why ricoh aficio mp 171 spf is showing servical sc 542?
because in some moment the fusing temperature was more high than the optimal. maybe it is just because of precaution issued the SC542. or maybe is problem . you need to reset the SC542 by entering the service mode. for this if you call service they will charge you big money. so if it is just issued just as precaution by doing the following procedure the machine will work fine again. but if the code do not clear do not repeat the procedure more than ones that you can make bigger damage that it has have before the code. so follow the next procedure: first enter service menu by pressing the following keys in order. press the yellow clear key the pres 107 and then press the red clear/stop key until on he screen write service menu or something other than the usual screen. after that appear. turn the machine of by the left side switch and wait 5 seconds, than turn it in again. if starts to work everything is okey . if the SC542 appear again do not repeat the procedure. call a serice techician
Oct 18, 2016 | Ricoh Office Equipment & Supplies
WHAT IS SERVICE CODE # SC542
SC542 error = Fusing temp. warming-up error
Jul 16, 2014 | Ricoh Aficio SP3410SF - Multifunction fax...
SC542 Error
First fix fuser unit thermistor bad then service mode and rest set code
Feb 06, 2012 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Feb 28, 2011 | Gestetner 2212 Digital Imaging System...
Transformer blew at our office yesterday, now calling for a service call, error code SC542???
sc542 is a fuser temperature error code, which could either be something simple (a bad sensor reading) or something serious (a blown thermostat). Either way you'll need to have your service technician come take a look at it and reset the code. (Unfortunately, turning the printer off and back on won't help.)
Sep 14, 2010 | Gestetner C7526dn Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
SC542 code appears on my Rex Rotary 2822, give solution please
This means the fuser has an error. You can not reset the code even if the fault has passed without entering the service mode. If you need a service manual for this let me know and I will send you a link.
Apr 21, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 1027 All-In-One Laser Printer Logo
169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
