Question about Toys
I have a wooden Brio drawbridge that the plastic piece that the bridge pivots on as it raises, is broken.  It looks like a fairly easy fix if I could get the part but I can't seem to find a supplier.  Can you get these kinds od parts?
  • Anonymous Mar 18, 2014
    I am in search of the Drawbridge instructions, I bought a Lionel Draw Bridge instructions.
I contacted Brio Corporation directly and they are sending me the broken part
Posted on Jan 28, 2009
Hoover Spinvac F5915900. Trigger no longer causes a release of soapy water on floor. It doesn't have tension, fairly loose, but still in slots. How do I fix this problem?
The trigger that you pull to release water snaps into plastic pieces inside the handle where it pivots to push on the rod that goes down to push on the regulator that lets the water flow. If the trigger is pulled too hard it can break the plastic it pivots in. If this happens the rod doesn't push hard enough on the regulator to let the water flow. Remove the screw at the top of the handle to remove the handle part holding the trigger to see if this could be causing your problem.
Jan 28, 2017 | Hoover Vacuums
Flash won't work on D70
Does it pop up? There can be a number of causes for this problem, from a bad circuit to a broken flash tube. Without a complete description of the symptoms I can only give you the most common cause of flash problems in the D70. If you can pop up the flash, remove the two screws under the flash and carefully pry off the flash cover. Check the flash pivot on the release side. There is a plastic piece that stick up from it that the wires go through that snaps into place, and it has a plastic piece that sticks out and operates the flash up switch. Impact can cause this pivot piece to fall into the camera so that the switch does not work. Also sometimes impact can cause the top blade of the switch to fall below the plastic piece so it doesn't close.
You have to remove the top cover and pop it into place from the inside (you could use a small hook but the wires that go through the pivot are very small and easily broken. There are any number of dis-assembly instructions on the internet, just seach. Make sure you discharge the flash capacitor or you can get a nasty shock
Apr 21, 2013 | Nikon Cameras
Imaginext Batcave drawbridge won't go all the way up.
Turn the batcave over and remove the long black piece in the center section (5 screws). Re-align the two white gears so that the drawbridge stays shut. Then put everything back together. Easy 2 min. fix.
Jan 06, 2013 | Fisher Price Imaginext DC Super Friends...
How to fix a broken Maestro Lutron button?
I will take anybody's broken Lutron dimmers.
Please let me know...
Marty
Feb 02, 2012 | Lutron Electronics MAW603RHWH Maestro 3Way...
Does anyone have information where you can get replacement rubber tires / wheel grips for Brio electric train engines? (wooden tracks) We have a few electric engines that can no longer climb the hills...
I dont know where you can get replacement tyres. But here is a fix for the problem:
Using tweezers then fingers, pull off the existing tyres.
Take ordinary sewing thread, and wrap it around the V in the wheels (where the tyre was), about 20 turns or so, keeping the ends inside the V.
Put the tyres back on.
The thread forces the tyres further out, making some tread from the rubber available above the level of the plastic wheel rims.
Nov 06, 2010 | Thomas and Friends Repair Garage Fits...
How do I remove the third row seats from a 2008 Honda Odyssey?I want to pull both of them out temporarily so I can access BOTH the full floor and the deep well the seats normally fold into. There are three...
You haved to remove the bolts you are looking at and then fold the seat down remove teh other piece of plastic and remove those bolts. On the left and right side there are also a piect of plastic that covers the pivot bolts on the sides of the seats. These have to be removed also to access the bolts under them. This will allow you to remove the seat. POINTS TO REMEMBER. The Plastic pieces are not ment to be removed and will probably break upon removal. They are not cheep to replace. Also the bolts are set to a certain torque value to insure the passangers dont end up in the front in case of a accident. Also the seats have a very storng spring built into the pivot points to assist in raising and lowering the seat. Not easy to manually pull out to reinstall. Good Luck.
Jun 25, 2009 | Honda Odyssey Cars & Trucks
Removal of outer door
Not sure if this has been covered - how to remove the door from the oven.
If you look at the hinges theres a pivoting piece (under all that grease) like a zippo lighter lid. Flid that open towards you and the oven door will pop out when pivoted closed - hinges and all. It should be fairly easy to put back too. Then follow the other instructions - screws on door base.
Aug 26, 2006 | Zanussi ZBF360 Electric Single Oven
Toys Logo
93 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
