Question about Dishwashers
My G E Profile dishwasher PDW988ONOOSS has water standing, it appears to run ok, bit leaves water standing? Had a appliance person out who looked inside, and determined it needs a impel or motor?
Water standing, runs fine . I was told upon looking inside it needed a 322.00 fix of an impeller motor?
  • 1314 Answers
SOURCE: Dishwasher wont fill after repair
first check to make sure the water is on then take the kick panel off and make sure the float is engaging the safety switch and the valve is plugged up if all that's ok check to si if the mirco safety switch is good
Posted on Feb 11, 2008
IrishDruid
  • 2712 Answers
SOURCE: asko 1375
Do you mean to say that the washer does not go into the wash cycle at all, or washes poorly?
An answer to both can be found HERE.
This article HERE will help you determine if your impeller needs replacement.
Hope that helps. If you need further clarification, or have additional queries, please post back. If you are satisfied with my response, kindly take a moment to "Accept" my solution. Thanks.
Posted on Jun 08, 2008
SOURCE: asko 1375
kenmore quite wash making loud screaming noise-was told it could be something stuck in impeller. Could this be true and if so how can I check/fix this myself?
Posted on Jun 24, 2008
SOURCE: lg dishwasher with "LE" code
I had the same problem and it was the wiring in the door. The wiring was stuck to the "tar" type insulation on the door and one had melted and was broken-spliced and fixed wiring and insulated all wiring with lots of tape and now it works fine.
Posted on Feb 08, 2009
  • 177 Answers
SOURCE: My Dishwasher works but still leaves some standing water.
Check the filter unit located at the bottom (inside) rear for clogging. Sometimes food will accumulate in the filter and not allow the unit to completely drain.
Posted on Jul 24, 2009
Our GE Dishwasher is brand new and everytime we wash dishes the dishes leave a residue of cloudy white in all of our glasses. What can we do to fix this problem? Thanks so much! This is our Model GE...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 12, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water...
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Aug 03, 2008 | Bosch Dishwashers
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have some standing water in the dishwasher after running
I stopped my dishwasher in the process of dishes being washed because I eas leaving for 2 days & didn't want to leave the dishwasher running. Now I have standing water in the bottom & don't know how to remove it i.e., i.e., short of bailing? HELP!!!
Jun 02, 2010 | Whirlpool GU1200XTLS Stainless Steel...
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
I have a GE Profile Dishwasher Model # GSD4940Z00SS. It does not wash very well. Water stays at teh bottom after each wash cycle. We have blow air through tubes and looked for obstruction but can not...
I had a similar problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Aug 24, 2009 | Dishwashers
Spray arms do not turn. water to them but not
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Standing Water in my Dishwasher
hi this is the electric pump thats in your dishwasher. its probably seized up.remove and clean it just might be dirty thanks the appliance doc,
Oct 15, 2008 | Kenmore Dishwashers
Standing Water
are you leaving it long enough to finish it's programme or are you opening it when the drying light is on as some dishwashers leave a bit of water in the bottom to help with the drying programme
Dec 08, 2007 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
