Question about HP LaserJet 2420 Printer
Black line on right hand side of the pahe
When printing a page of text a black line appears about 30mm in from the right hand edge. Could this be telling me that the toner is almost at an end?
  • HP Master
  • 1,684 Answers
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Posted on Mar 25, 2013
SOURCE: Black lines on the right side
The vertical black line at the right-hand side of the page when the printed document includes an image is a problem with all currently available HP Laserjet 1018, 1020 and 1022 drivers. While waiting for HP to fix the problem (they haven't even acknowledged it yet in their webpage) you can bypass it thus: a) Click on the 'Properties' button. b) Click on 'Finishing' and select 'FastRes1200' (this makes the line narrower). c) Click on 'Basics' and select 'Rotated', i.e. printing the page from bottom to top (this elliminates the line completely, in combination with 'b' above). This is a home-made solution I found after numerous trial-and-error attempts and having downloaded several drivers from the web. As a token respect to all of us who have paid money to buy these printers, I hope HP will soon recognize and solve the problem.
Posted on Sep 25, 2007
  • 38 Answers
SOURCE: HP 4700 - tones dropping in on transfer kit w/ new toners
how old is it?
Posted on Oct 30, 2007
SOURCE: Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Posted on May 01, 2008
SOURCE: Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Posted on Jun 05, 2008
  • 25 Answers
SOURCE: printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Posted on Aug 14, 2008
My printer is printing black horizontal lines down the right side of the paper - what is wrong?
Needs Drum If you pull the drum unit out you will see on the drum different shades of color lighter is wear the lines come from. Buy a rebuilt drum much cheaper and they work, may have to reset the drum count if the change drum lite on...
May 02, 2014 | Brother MFC-8460N All-In-One Printer
Canon LBP 2410 Lazer Colour Printer -
Printing not dark enough or varied in darkness
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Jun 07, 2008 | Canon Office Equipment & Supplies
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Hi when printing black or grey outside edges
sounds like your black toner cartridge is getting low or not filled evenly. To fix this until it get a bit lower on toner just take the cartridge out and holding it up right give it a few shakes side to side. The will spread the toner power out inside and you should be printing normally again.
This can also happen if you moved or bumped the printer. Usually you only see this when the toner is low or after you print a lot of pages. Most text is in the mid of the paper so thats where the toner get s used the most.
Oct 23, 2009 | Samsung CLP-350N Laser Printer
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Thin black line 1.5 in from the right side of the paper going down the whole page
If it doesnt have a line on it when you scan it and open up the document then it's not going to be a scanner issue, more then likely, it's going to be an issue with the toner of the printer you are using to print with. Check the drum on the toner and you'll probably see the line in question on the drum itself. You'll just have to push back the flap that covers the drum on the toner if this is a laser printer... hope this help's if it does, please mark as a FIXYA!!
Oct 06, 2008 | Canon DR-9080C Path-Through Scanner
Vertical line down right hand side
crop toy jpg or bmp file from that side and then try I faced smae type of problem that process helped me you also try.
Mar 18, 2008 | HP LaserJet 1012 Printer
HP LaserJet 2420 Printer Logo
89 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
