Question about Dishwashers
Whirlpool Gold Dishwasher not draining completely.
Dishwasher is not draining completely, even after repeatedly running Cancel/Drain Cycle. Some discharge is going into disposal, so there is obviously not a complete blockage of the drain line. Should I follow D. Floyd Kalb's trouble shooting process posted on 2/8/10? How can I determine whether the pump or other components are defective if I determine that the drain hose is not plugged?
3 Suggested Answers
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
heatman101
  • 43501 Answers
SOURCE: standing water in my kenmore dishwasher after complete cycle
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
z
Posted on Sep 29, 2010
Whirlpool quiet partner II starts and stops. What should I check?
the first thing to do is unplug it for 3 minutes then check to see if it reset by running
Jan 07, 2018 | Whirlpool 24 in. DU951PWB Free-standing...
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
DISHWASHER WILL NOT DRAIN EVEN AFTER WE PUSH THE CANCEL/DRAIN BUTTON. I DON'T KNOW WHETHER TO CALL A PLUMBER OR WHIRLPOOL REPAIR.
First of all, if you have been using the gel pacs...stop! They don't dissolve completely and cause a buildup. This happened to me and we replaced the hose and solved the problem (about $25). I also had to take apart some of the assembly and scrap off the powdered substance that solidified around the drainage holes. Good luck!
Aug 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher does not complete cyele
Sounds like you might need a new Start button.
Mar 15, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
79 people viewed this question
Top Dishwashers Experts
