Question about Sewing Machines
When sewing, it jams up right off the bat.
I follow the manual, and the stitch pattern # and it still jams up. I have the threading done right and everything else right, just keep jamming up on me when I try to sew. It keeps showing c4 but I check and it's fine. Can you help?
  • Sewing Machines Master
  • 7,365 Answers
Try rethreading the machine top and bobbin
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint or loose
threads
make sure the top thread has not come off the thread take up lever
Posted on Jan 22, 2013
  • Patricia Smith Mar 16, 2015
    I am having the same problem and I've followed every instruction that I've found with no solution. I just bought this machine and I'm so frustrated cause I can't use it. The stitches look fine so I don't understand why I keep getting the same error code C4
SOURCE: euro pro model 385W sewing machine
Hi FixYa,
I'm fifi1076, and I'm having quiet a good bit of trouble with my sewing machine.
I'm new at this site so I don't know if I'm doing this correctly or not so please
forgive me if I do something I'm not suppose to do!!!!
I copied this question from off of this site for I wanted to make certain that
whoever answers my question will understand that all of the question
doesn't pertain to my problem.
"when we have it threaded the top thread keeps getting jammed up in the bottom bobbin. if i redo the bobbin as shown in manual then the bottom thread will not loop so it will stitch"
This is the only part that pertains to my problem...... when I have it threaded the top thread keeps getting jammed up in the bottom bobbin......and I can't get it to sew at all....it won't do nothing.....the motor will just sit there and grind.
If whoever can help me with this and can give me a solution I will be forever gratefull
Thanks,
Kay Nowicki
Posted on Sep 10, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
mohammed387
  • 1952 Answers
SOURCE: i have the basically the same problem. i was
Check the easy stuff first:
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correctly.
the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly.
the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. If that is the case.
Posted on Aug 04, 2009
Zenqi
  • 208 Answers
SOURCE: prolectrix 8 stitch sewing machine top thread
Sounds like the take-up lever is not threaded.
Remove the thread from the machine, turn the handwheel until the take-up lever is at its highest position, raise the presser foot and rethread the machine. Set the upper tension dial to 5 and retry.
Posted on Aug 18, 2009
Testimonial: "cheers machine running fine now only occaisional jam , but mostly smooth "
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
How do i make an x follow the oncreen progress of sewing a single run quilting pattern
Pantograph - IntelliQuilter® ' Computerized Quilting ...
www.intelliquilter.com/iQpedia/Pantograph.php
A pantograph pattern is one that goes from edge to edge, over the entire quilt ...patterns - there are some interesting combinations you can use to create ... Remember to align the on-screen quilt to the quilt on the machine before you sew (use the ...Touch Realign, and follow the on-screen prompts: Find a reference point on ...
Baby Lock: Ellure
babylock.com/sewing/ellure/
With a 5" X 7" embroidery hoop and a wide variety of built-in stitches and designs, ...With 120 frame patterns and a large library of built-in designs (including 40 ... cover so you see your progress and avoid running out of thread mid-stitch. ... Baby Lock IQ Technology is what makes Baby Lock machines so smart and efficient.
[PDF]Quilt Magician Manual updated 4-23-12.indd - TinLizzie18
tinlizzie18.com/images/Quilt-Magician-Manual-updated-4-23-12.pdf
This manual will cover everything you will need to know to RUN your Quilt ... Let's getto know your Quilt Magician™... .... pattern boxes at one time, the system will onlyrun the pat- ... You can have as many patterns as you like in each pattern box. Circle for. Start. (X) for ... button and follow the on screen steps to re-calibrate.
[PDF]SideSaddle (SS) Users Manual - The Quilting Solution
Jan 11, 2016 | Sewing Machines
How do I use the thread cutter?
Most of the time, you will sew a seam and then do a few stitches after pressing the Reverse button. Leave the presser foot down and press the button with the scissor icon. (That's the top-most button in the row that curves up from the needle area.) The LED will blink. If the thread cutter LED blinks when you turn on the sewing machine, press the button again. The machine will remember if the thread cutter was in use when the power went off. For some thick threads, the auto-thread cutter will not work. Instead you'll need to lift the presser foot and bring the item up to the thread cutter on the side of the sewing machine. It's towards the back of the side of the sewing machine near the needle.
You can even program in the thread cutter in memorized sewing pattern by selecting pattern 48 and pressing the M button after all the other stitches for the pattern are added to the program.
Do remember to clean the thread cutter regularly. Lint or thread buildup will interfere with the mechanism. The cleaning steps are on page 61 of the manual.
Janome has the instruction book for the Memory Craft 6300P on the product page: http://janome.com/en/machines/sewing/6300p/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/professional-series/inst-book-6300peng-fr-sp.pdf .
I hope this helps.
Oct 22, 2015 | Janome MC-6300P Heavy-Duty Computerized...
Thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Mar 12, 2010 | Singer 5050 Mechanical Sewing Machine
Sewing machine skipping stitches and shredding thread
http://www.allbrands.com/products/15289-brother-pq1500sl-9-arm-straight-stitch-sewing-quil
Oct 03, 2017 | Brother Sewing Machines
No stitch happening
May sure you are using the correct size of needle and thread suitable for the fabric. make sure the thread in the bobbin and the needle is of the same weight or size. Make sure the needle is changed often - after the completion of an garment. After much use the needles become blunt and cause problems with your stitches.
Also, if the bobbin is jamming that is normally because the machine is threaded incorrectly, or the bobbin case thread is wound unevenly, or the bobbin case is not put in properly.
Try this! Just stop for a while, give yourself a few minutes to relax. When you return pull the User's Manual and slowly go over the instructions, especially the "troubleshooting" section. Also, rethread the machine and the bobbin case by carefully following the steps in your User Manual. I have found that it helps me tremendously when I have problems. Hope it help. Happy Sewing
I have similar problems
Aug 02, 2009 | Janome 8080 Computerized Sewing Machine
Problem with Brother XL-3750
can u chart me on whatsapp +2348189956612 so that i can help.
Oct 03, 2017 | Brother XL3750 Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Feb 01, 2008 | Sewing Machines
Thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Nov 04, 2007 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
107 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
