ONKYO CP-1046F TONE ARM - Audio Players & Recorders
2 Suggested Answers
  • 1044 Answers
SOURCE: free service manual for Onkyo cp 1036a turntable
Go this website www.analogalley.com/m_onkyo.htm
Posted on Apr 19, 2010
Have a Onkyo DV-CP 702 that shows loading but never goes any further or if it does then shows error of no disc or no playing, What is problem and how do we fix?
Hello, I am sorry about your issue. If you tried multiple discs and they have the same issue then the player would need to be serviced or replaced. Thank you, Onkyo USA
May 10, 2017 | Onkyo Televison & Video
How to ground onkyo cp-1036a
If the receiver doesn't have a ground lug, you can loosen one of the cabinet screws and connect your TT ground wire to the chassis that way.
Dec 28, 2015 | Onkyo Audio Players & Recorders
Automatic turntable adjustments
The Service Manual may be downloaded at:
http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
You will have to register (free) before downloading.
Mar 28, 2014 | Audio Players & Recorders
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
Free service manual for Onkyo cp 1036a turntable
Apr 19, 2010 | Audio Players & Recorders
Connect Onkyo CP-1020F Turntable to Theater System?
Yes. It needs to have Line Level (slightly amplified or pre-amp'd) before your home theatre system can 'hear' it.
Oct 06, 2009 | Audio Players & Recorders
I need a drive belt for my CP 1100A turntable!
Measure the length, width, and thickness. Go to www.mcmelectronics.com and find the belt that is closest.
Apr 21, 2009 | Audio Players & Recorders
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
 Grubhead
Grubhead
