SOURCE: fitting monobloc kitchen diagram on pipe fittings
The tap should have 2 pipes about 6-10 inches long and almost the thickness of a maker pen {10mm or 15mm]
U will need either a 10-15 connection or a 15-15 connection either straight or elbowed according to routing need to main pipes [& these should also be 15mm
connections are fixed either with solder or have nuts on each end to tighten [compression] or are just push-on ["Speedfit"]
Ger back if u need more
SOURCE: When hot water is turned on the pipes make this
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
