Question about Toshiba Satellite 1805-S253 Notebook
There is only a phone port and the types of cord thats connected to my dsl are different what type of cord do i need is there a universal one
  • Anonymous Jan 27, 2009
    no i dont have that i guess i have an older model the one with the dvd player in the front but it looks just like this one
  • Toshiba Master
  • 19,396 Answers
The model in title has integrated LAN, if your model does not have integrated line , with RJ45 socket built into computer, then you need to use an external network adapter.
The best choice on a laptop like this is using a PCMCIA ethernet adapter, like the ones listed here.
Posted on Feb 03, 2009
    Master:
  • 413 Answers
The one that connects to your dsl should be Ethernet. Are you sure there is no network port on your PC? the image below shows where this port is. does the dsl fit in here? there is only a phone - cf5ca22.jpg
Posted on Jan 27, 2009
  • 1 more comment
  • Dan rogers
    Dan rogers Jan 27, 2009
    This is the image i meant to post. Not sure why it didn't show
  • Dan rogers
    Neither did my edit. It is the square one on the left of the center. If this one has something in it you will have to buy a hub or a switch
  • Dan rogers
    Dan rogers Jan 28, 2009
    is this the port you found or is yours different?
Telecom Issue, when a Netgear router (DG834G) linked to a small server unit, dissconnects the telephone line. The router works fine but no dial tone on the phone side of the micro filter. Any assistan
a POTs (plain old telephone) line should never be connected to a router. that adsl filter does not make a phone line share a data line.
ADSL is a type of internet service supplied over a phone line. think of it as raw (unusable) when its on the phone line. then you use your dsl filter/splitter to feed the raw internet into a special dsl modem and the other port can be used by a standard phone.
you will know a dsl modem when you see it because its uplink or internet port will only be big enough to fit a phone cord into, not an internet cord. these dsl modems then feed usable internet to your routers and all devices on your network. but, like i said before, at this point it is too late for your phone and internet to share the same wire.
OK, thats not entirely true
pin out of RJ45 internet
1=orange/white *
2=orange *
3=green/white *
4=blue
5=blue/white
6=green *
7=brown/white
8=brown
1,2,3+6 are used in a typical network
if your network is typical you can "get fancy" and use 4,5,7+8 for telephone or even put 2 data lines on the same wire (not recommended for long distances). however, this may involve cutting some wires and splicing them together or something.
Sep 14, 2012 | NetGear Computers & Internet
Phone isn't working. Message flashing says "Waiting for synch"
This happens on the older software levels of the Mitel phone systems when the phone type programmed does not match the phone type connected. Example: if the phone system programming has a 4015 phone type for that port and you connect a 4025 phone you will get this result. Another cause could be the port you are connected to is analog(used for analog devices such as fax, credit card, modem, or standard single line phone) instead of digital; you would get this result even on the latest software levels.
Assuming that this is the same phone that has been at this location and was working previously, try a different working 4025 phone at this location. If the different phone works, then the problem is in the phone and needs to be sent for repair. If the different phone doesn't work, change the line cord to eliminate possible bad line cord. If the phone still does not work, the problem could be in the outlet, building wiring or in the telephone system. At this point you likely need to call a service technician to track where the problem is.
Dec 10, 2010 | Mitel Superset 4025 Corded Phone...
Hello,i need serious help as i am driving myself bananas trying to get my dsi to synchronize with my wireless router. Please can you give me some professional advice,as nobody seems to know the answer and...
Why don't you call your ISP (Internet Service Provider) and get them to trouble-shoot?
If they don't help, switch to a different ISP.
Or .........................
Turn the DSL adapter off.
Turn the router off.
Turn your computer off.
Check that the telephone-line wire from the wall-port is connected to the DSL adapter.
Check that an Ethernet cable from the DSL adapter is connected to the 'WAN' (or 'Internet') port on your router -- check both ends of the cable.
Check that an Ethernet cable from one of the 'LAN' (or 'network') ports on the router is connected to the network-port on your computer.
Turn the DSL adapter on.
Wait for its lamps to settle-down to a repeating pattern.
Turn the router on.
Turn the computer on, and let it boot into Windows.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway . . . . . . . . . : 19.168.x.y
where 'x' and 'y' are unique to your router.
Start Internet Explorer
Type http://www.google.ca
If its connects, you're "golden".
If not, type http://192.168.x.y
Login to your router, using the current (or default) ID/password for your specific router.
Click Status
Click WAN
Check that the router has obtained an IP-address from your ISP.
Telephone your ISP, and ask for "technical support".
Now, 'login'
Dec 10, 2010 | Computers & Internet
Hello. I bought this modem with wi fi ,dsl router. How to set it to use this modem as a router.I want to connect my pc with lan cord & use wifi connection with my laptop and phones.
Turn DSL-router off.
Turn Actiontec off.
Turn computer off.
Connect:
* telephone-port in wall <--- 4-pin telephone wire --> DSL router
* Ethernet port on DSL-router <-- Ethernet cable --> WAN port on router
* One of the LAN ports on router <-- Ethernet cable --> network-port on your computer.
Turn DSL-router on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn Actiontec on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn computer on, and boot it.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Type http://192.168.123.456 (or whatever numbers you saw)
Configure the wireless adapter inside the router
(enter an SSID, choose 'WPA' encryption, enter a password)
Disconnect the Ethernet cable from your computer
Click "View Available Wireless Networks",
and select the SSID that you provided.
Enter the password that you provided.
Oct 21, 2010 | Actiontec GT701WG Router (actiongt701wg)
How to hook up the Linksys Wireless-N WRT150N Router to DSL?
Connect the dsl modem to port on the router that says Internet
connect 1 pc to any available port on the router(1,2,3,4).
Open your browser and type 192.168.1.1 in the address bar
It will prompt for a username/password window. leave username blank,password admin. Press enter
Normally if you have dsl, you need to set the internet connection type to pppoe and put in your username and password that your ISP provided you. then save the settings.
Oct 04, 2010 | Linksys Wireless-N WRT150N Router
I need to know how to hook up a westell versalink ? i dont have directions & i have a dial up connection on my desk top . do i need a server ? i have no idea what to do !!
In order to setup the versalink you need an active DSL account, a phone line cord, a phone jack, a pc or mac, and an ethernet cord or wireless ethernet card. Plug in the phone cord to the phone jack and to the DSL port on the versalink- once the DSL light is solid, plug in the ethernet cord to the computer you have, or enter the wep key on the bottom of the modem into the wireless manager for your system. At that point, if you need further assistance in getting online, contact Verizon or Bell (whichever is your DSL provider)- they can and will walk you through setting up the versalink to connect to the internet.
Oct 03, 2010 | Westell Wirespeed VersaLink...
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
How do connect a router?
hi,
may i know the model#, and i will try to look for you a manual for that.
Jul 09, 2009 | Compaq Presario sr1111nx 2.53GHz Celeron...
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
If the supplied phone cord is not long enough, you can extend it. For
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Toshiba Satellite 1805-S253 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
