Question about EliteGroup Computers & Internet
661gx m7 motherboard beeps on start up
Beeps
5 Suggested Answers
hvpatel
  • 152 Answers
SOURCE: g31t-m7 motherboards can use inter Pd. 800 cpu
if your post code has completed so
heat problem or smps problem or ram problem or
remove all datacable exm : hdd ,writer,fdd and power on
Posted on Jan 18, 2009
mahhek
  • 662 Answers
SOURCE: computer switch can start the board up but cannot
You have to press and hold the power switch for 6 - 10 seconds to turn it off
Posted on Sep 18, 2009
Testimonial: "Yes, this was helpful but the problem was because the motherboard power cable was not connected to the motherboard. Thanks, Waheed "
  • 53 Answers
SOURCE: CPU Support
Go to your motherboard website and check it's CPU specificaions
Posted on May 25, 2010
Ezrahite
  • 2632 Answers
SOURCE: I need the best, fastest,
Welcome to Fixya. If you want to upgrade your Processor you can use a dual core cpu. I proivded the list of processor that is compatible with your motherboard. By the way the socket of your motherboard is a LGA 775
Lga 775 Processors
Thanbks for using Fixya.
Posted on Jul 02, 2011
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
Tip
Computer error beep codes
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
you can now simply analyze if what is the problem of your computer...
on Feb 13, 2010 | Computers & Internet
G31t-m7 no beeps no display
If your getting no beeps, its usually a video card issue. G31T-M7 has an onboard video card. Can you try plugging you montor to the VGA port and see if anything comes up. If still no picture, are fans turning? Might be a power supply failure.
Nov 28, 2011 | EliteGroup G31T-M7 Motherboard
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I need the best, fastest, most powerful and recent CPU and RAM available for the AcerPower Series 661GX-M7 motherboard; can it use a dual core processor?
Lga 775 Processors
Jul 02, 2011 | Computers & Internet
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
I need a manual for a ECS 661GX/800-M7 Motherboard. Where can I find one?
This link leads you to the online manual for ECS 661GX/800-M7 motherboard. You must have an adobe acrobat reader installed in your system to view this.
http://download.ecsusa.com/dlfileecs/manual/mb/eng/p4/661GX_800-M7.pdf
Please give this manual a four thumbs up ratings.
Thank you for using Fixya
Sep 13, 2010 | Office Equipment & Supplies
CPU Support
May 25, 2010 | EliteGroup 661GX-M Motherboard
Computers & Internet Logo
64 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
