Question about GE Profile JGS968SHSS Gas Kitchen Range
GE Profile JGS968SHSS stove won't heat - display stays at 100F
Mid-way through cooking (long, slow-cook) I returned to find the oven very cool though set to 350F. Turned it off and reset temp to Bake at 350F. Oven never heats and display shows 100F. Temperature never rises. Broiler works as normal. Oven Cleaning Cycle - oven gets hot too and works as normal. When set to regular Bake program, oven fan (from top) turns on, but inner Convention Fan doesn't turn. I cannot find any Service Manual; would much appreciate help in troubleshooting my problem. I've looked for thermal fuse protectors, but it's not obvious to me where they are located. Much appreciate any advice you can offer.
IrishDruid
  • 2712 Answers
SOURCE: Our GE Profile Oven is not heating up (stove works)
Please check here for possible troubleshooting steps:
http://www.repairclinic.com/0088_13_1.asp#Level1_2
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 04, 2008
SOURCE: GE Profile Spectra JGBP85WEB5WW Taking Too Long to Reach Temp
GE use and care manuals
Posted on Dec 06, 2008
Maytag317
  • 1136 Answers
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
EllaWatson25
  • 725 Answers
SOURCE: ge profile (model #: JGBP90MEB3BC) oven won't
This is a gas range isn't it? We can help you get this oven heating up again. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will get the correct parts out to you to get you cooking again asap!
We look forward to working with you. Thanks, Ella
Posted on Dec 11, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
    If you just put the fan blade back on, it will almost certainly fall off again.
    The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
    I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
    There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
    d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    May 20, 2009 | GE Profile Spacemaker Over-the-Range...
    GE Profile stovetop w/4 burners doesnt stay hot enough to cook on anymore
    I would check to see if you have 220 Volts to the stove, even if you have only one leg with 110 volts to stove it will let the burners get half hot. with out the model number i don't know about any censers. The flat tops have temp sensors on them. but not that operates for all four. I would check at wall receptacle first for 220 volts first but only if you are qualified to work with electricity REMEMBER it can injure or KILL you.
    Feb 05, 2018 | Kitchen Ranges
    GE gas stove
    sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
    Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Oven stopped working while cooking a meal
    it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
    Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
    Probe light
    I had the same problem today (my wife overflowed a pot of chicken stock last night, so there was liquid all over the cook-top, and some probably got down behind the control pannel). Based on the solution to a problem that seemed similar, though definitely not as exact as your description, I checked the probe connection (unscrewed the retaining nut, then unscrewed the two sheet metal screws holding the housing in place, then gave the probe connection a gentle tug to ensure that it was still properly connected). Finding nothing wrong, I replaced the housing and retaining nut, and the lights were no longer flashing.
    Jan 01, 2007 | GE Profile JGS968SHSS Gas Kitchen Range
    GE Profile JGS968SHSS Gas Kitchen Range Logo
    122 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
