Question about Humidifiers
Need a rubber gasket for 2.1 gallon Model MW-500K-88 Welbilt Ultra Sonic Humidifier
Need gasket
3 Suggested Answers
SOURCE: sunbeam ultrasonic humidifier model 696-12
I want to order this rubber gasket
Posted on Feb 24, 2009
  • 189 Answers
SOURCE: How do I clean/sanitize my humidifier?
A solution of water and white vinegar will remove the mineral deposits built up from the water. Rinse "very" good, then wash out with a solution of 1 part bleach and 3 parts warm water.
Posted on Mar 29, 2009
Walgreens Dual tank humidifier 2035 stopped working
I've never seen this model, but it would suggest that the unit is unable to function due to either an electrical failure or needs a serious deep cleaning (esp.the part that interacts with the water to form mist.) I would completely empty the unit and clean it, then partly fill the reservoir with 50/50 mix of white vinegar and water and let it sit for 24 hours (possibly longer) to remove any deposits. (Doesn't take much build up to kill the ultrasonic process). Other than that, try calling the manufacturer and see what they will do for you. (Think it's Sunbeam).
Dec 21, 2015 | Walgreens Dual Tank Ultra Sonic...
Where do I find manual for germgaurdian H3000 humidifier.
http://www.guardiantechnologies.com/product-instruction-manuals/
Germguaridan website.
This manual can be found under discontinued models. This was most likely discontinued because it is very sensitive and quits working too soon because of the ultrasonic sensor.
Dec 10, 2013 | Germ Guardian H-3000 Ultra-Sonic...
Vicks warm air humidifier replacement part
Does this help you? http://www.appliancefactoryparts.com/humidifiers/vicks/v5100ns.html
My OX husband trod upon his new humidifier LOL...broke the tank and I cannot stop leaking. Anyone have a site where I can buy just a Vicks tank?
Feb 18, 2013 | Vicks Warm Mist V745A 1 Gallon Humidifier
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
Emitting a powder residue
its minerals in your water. not harmful at all.
Aug 07, 2017 | Vicks V4500 1 Gallon Humidifier
Humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
May 18, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Vicks V3100 1.2 Gallon Humidifier leaking
Check if the cap has a gasket or o-ring and is not worn. There are two designs for this model. The older model has the fill cap and valve together. The new design the fill cap and valve are at different locations. The new design has no hole in the bottom of the unit.
You can fixed the problem using a 1-1/2 inch washer for brass tubular found in the plumbing isles in HD or L. The rubber washer is 1 or 2 mm smaller then the grooves in the fill/valve cap. You can stretch the washer and it will fit perfectly in the grooves. When putting the fill/valve cap back with the washer, it will be tighter then before. Firmly turn and you should not have any leaks and make sure unit is level. You can plug the hole because the new design does not have a hole in the bottom of the unit.
Nov 28, 2008 | Vicks V3100 1.2 Gallon Humidifier
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Humidifiers Logo
130 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
