Question about JVC TH-C50 System
I'm trying to connect my Sony HD TV to my JVC TH-C50 Home Theatre. I have the connections where they are supposed to be but cannot hear any sound. What do I put the source on?
  • 93 Answers
SOURCE: Surround Sound Does Not Work
Check NTSC/PAL settings.
Posted on Oct 03, 2007
SOURCE: JVC TH-S3
try setting tv to s-in it should be in the menu
Posted on Feb 17, 2008
SOURCE: home theater system jvc th-d60
This is from the TH-D50 User Manual:
The connected TV is not HDCP-compatible. (“HDCP ERR” appears on the display.)
Disconnect the HDMI cable and connect it again, or use a shorter cable.
Posted on Dec 31, 2008
SOURCE: Cannot TV to play throught JVC TH-C50
i have a jvc th-c60 and only recently started using the system for surround on my tv.
in addition to the surround system, i have a conventional vcr/dvd player. i mention this because i have my cable line routed through the vcr/dvd player - all other connections (audio in/out, etc.) are directly from back of tv to surround unit console. assuming all connections are correct, set the jvc unit to show "VCR" on the unit display AND set your surround option to "All surround". The "all surround" may not the exact term, and not sure what your unit has the same notations, but you should be able to cycle through the surround options and determine when you have sound coming from all speakers. also, on my th-c60 unit, the unit display denotes which speakers are producing sound (or should be producing sound).
and, yes, the college football games sound awesome in surround mode.
Posted on Jan 09, 2009
  • 60 Answers
SOURCE: how can I get sound from cable tv to come out jvc
You need to a cable connection from your TV to either:
  • the AUX (in) connectors at the back of the main unit. This is usually done with a simple RCA-cable, assuming that your TV has analog audio output.
  • To the main units optical (digital) input through an optical cable, assuming that your TV has a similar output.
Posted on May 31, 2010
Getting tv sound from home theater speakers
Connect your sound from the cable box out to the JVC theater audio in jacks. This will give you sound through the speakers.
Jan 29, 2014 | JVC TH-C50 System
Sony BDVE870 Low Volume
use equalizer to increase volume
May 19, 2012 | Sony Audio Players & Recorders
How do you connect a jvc th-c50 hometheater to you tv?
By comparing the unnamed TV's manual and capabilities to those of the TH-C60.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-C50J-Home-Theater-Systems-manual/id/318ci575/t/2/
Jul 06, 2011 | JVC TH-C50 System
How can I get sound from cable tv to come out jvc th-c50
May 31, 2010 | JVC TH-C50 System
Listen to DTV DVR output on TH-C3
im not familiar with this model. can i assume it is a small home theatre system with limited inputs?
in that case, the best thing to do is to feed all your devices...cable, dvr, dvd, etc....into the tv.(audio and video). then use the audio output of the tv to the input on the receiver. you may have to go into the tv menu and set the audio output to the speakers in the tv to fixed mode for a constant level out to the receiver.
good luck
Dec 08, 2009 | JVC TH-C3 System
Sounds cuts out if volume is over 30
hey
I have been has same problem for long time, actually problem was on and off... the reason was short circuit of speakers or speaker connections.
I find a little peace of cable stack inside of the connection handle. you know all the cable stick on back...
well what you can do is, unscrew all the screw back and the bottom of the box. slice the electronic box, just check connection piece is clean cable free....
use always clean cable and don't put it too much.
it is very easy to fix
http://www.myfixtips.com/blog/av-receiverhome-theatre/no-sound-from-jvc-th-m303-home-theatre-system-456.htm
Oct 11, 2009 | JVC TH-M303 System
No sound comes out of my home theatre hen i plug it on my tv
hello
use the link below to check out if this is your tv. http://www.p4c.philips.com/files/2/29pt4273_75r/29pt4273_75r_dfu_eng.pdf
if it is, then go to page 5 in the manual.
connect L/R from monitor out to the AUX of your amplifier. when you want sound from the tv, select AUX as source from the front panel of your amp.
hope this helps
May 24, 2008 | Audio Players & Recorders
Connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Feb 10, 2008 | Sony DAV-IS10 System
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
Home theatre problems sound
Did you try to connect AUDIO OUT from your TV to AUDIO IN on your package?
Oct 04, 2007 | Sony DAV-C700 System
JVC TH-C50 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
