Question about Broan-NuTone CV350 Central Vacuum
I have a broan central vac 24 yrs old ,vac works if you turn sw on cannister,not by plugging hose att,is this a major problem,thanks
    New Friend:
Broan 450 air-watt and 8.5 amp power unit. Covers 3,000 sq. one 30-ft. crush-proof hose with on/off switch, one 10-in. wide hard floor brush features swivel neck for easy maneuverability around furniture. My new home is just under 2000sf. Will this new unit have enough suction?? Just buy or don't??
Posted on Feb 28, 2013
4 Suggested Answers
  • 95 Answers
SOURCE: I have a 3 year
A great way to check if your switch in the hose is bad would be to turn the hose sideways in the inlet. If the unit turns on you most likely need a new switch.
Posted on Jan 20, 2009
  • 95 Answers
SOURCE: NuTone CV353 Central Vac does not start when hose is plugged into
Try to plug the hose in sideways. So the top of the hose is rotated 90 degrees. If the unit turns on then there is something wrong with the hose. It might be a short or it could be a bad switch on the handle. If the unit still wont turn on I would think that maybe the low voltage wire got disconnected from the unit or there is a break in the low voltage wire somewhere along the way. Let me know if you plugging the hose in sideways works.
Posted on Feb 22, 2009
  • 4 Answers
SOURCE: NuTone Central vac won't turn off
If the central vacuum tank will not turn OFF even with the switch in the “OFF” position, then the low-voltage wires should be disconnected from the tank. If the tank continues to run and still will not turn off, then most likely the relay inside is defective (but it could be a defective and/or shorted ON/OFF switch). If with the low-voltage wires disconnected the tank is able to then be turned off with the switch, then there is a short in the low-voltage wires or a hose is plugged into an inlet somewhere. ~ TTURAMBAR
Posted on Mar 27, 2009
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
My BROAN CV-110 hose with the rug beater only works if I turn it on from the base unit. Shouldn't it turn on when I plug the hose into the wall recepticle? Do I need to replace the hardware at the end of...
In order to do this right you need to get in touch with the Broan Company. This could be difficult to do.You can get a VAC repair man that could answer you as well. They could even have parts for your machine.
Nov 05, 2017 | Vacuums
My central vaccum just stop working last night. It does not turn on at all.
I've gone through 3 vx475 vac in the past 7 yrs. Last one was sent to me in Apr 2010. Just yesterday, once again, my vac just quit. Green power light is on but no other sign of anything. Had a burning smell when vac quit, like motor just fried. Called Nutone again and they can't imagine whats going on but will send out another vac free and was told to throw out old one. They said dust may get into the motor and cause it to quit. These vacs aren't cheap, can't imagine that its so simple to just call up and have a brand new one sent to me. I've asked if they are rebuilt units and was told no. So my advise to you, if you haven't already, is to simply call them up w/model and serial # and they shouldn't give you any prob. good luck.
Sep 03, 2010 | Broan-NuTone VX475 Bagged Central System...
Central vac will not turn off
You have a defective internal relay on the vac. Check for warranty coverage as this is a common occurrence on these big box store units.
If beyond warranty the relay should be a straight forward unit, miniature circuit board type plug in device. Find a Broan Nutone service center or take to vac pro shop for parts.
Nov 01, 2009 | Broan-NuTone VX475 Bagged Central System...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Mar 11, 2009 | Broan-NuTone VX475 Bagged Central System...
Feb 22, 2009 | Broan-NuTone CV353 Central Vacuum
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=567634
Generic problem for all Vacuums
I have a 3 year
posted by patfitz on May 03, 2008
I have a 3 year old NuTone CV 353W central vac system and recently the switch on the hose handle does not turn the system on from any outlet in the house. I have to plug the hose into the outlet and then turn the unit on from the switch on the canister. Any help would be greatly appreciated. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that come to mind, 1st. you may have a bad switch in the hose and in most cases that can be repaired – if not you would have to purchase a new vacuum hose. 2nd. You may have a bad inlet valve in your hose and most of them are low volt of which would only cost less than $10.00 and can be replaced yourself unless you have what they call a SuperValve of which has 2 low volt wires and then it is wired to your home electricity and that should be replaced by an licensed electrician. It is a low volt and high volt inlet.
#3. the last thing you may check id that you may have a bad relay in the canister itself. Because you should be able to turn on the Central Vac with the switch on the hose and everything should work just fine . feel free to contact your local vacuum cleaner dealer in your area of call the Nutone Factory cust serv line for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://nutone.com/ Customer Service
Nutone Inc.
9825 Kenwood Road
Suite #301
Cincinnati, OH 45242
Customer Service 1-888-336-3948
Technical Support 1-888-336-6151
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Broan-NuTone CV450 Central Bagged Central...
Vacuums Logo
140 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
