Question about Ricoh Aficio 2018D All-In-One Laser Printer
SC556 error This machine was given to me without a manual. The machine was moved a couple of times (remained upright but went up and down ramp of uhaul truck..kinda bumpy), so I am not sure if something came loose at that time. When I plug the machine in and power on, the screen says call for service with a SC556 error message. Please advise if I am able to fix this. Also, is there another site I am able to download the manual for this machine besides the Ricoh website? I am not able to find the manual for this machine there. Thank you so much!!!
JayBlair
  • 328 Answers
SOURCE: Ricoh 3310L Fax machine - 'Time to change PCU'
You need a new drum. Photoconducter unit. Cost about 140.00 I sell them or you can shop on EBAY
Posted on Aug 10, 2007
  • 37 Answers
SOURCE: Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Posted on Nov 16, 2007
jaylex
  • 417 Answers
SOURCE: PCU?
Hi the you will be able to purchase the PCU (Photo Conductor Unit) it is customer changeable so type in the following in google there you will be able to find a store that sells them.
Photoconductor unit for ricoh 3310
Thanks J
Posted on Jan 28, 2008
STP162
  • 132 Answers
SOURCE: Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Posted on Dec 01, 2008
  • 161 Answers
SOURCE: SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Posted on May 06, 2009
How many time I need to wait until connecting my refrigerator when I move it
if it remained upright all the time , it will switch on immediately and run
if you failed to follow moving instructions and laid it down then 24 hours to allow the oil to get back to the compressor
Nov 24, 2016 | Refrigerators
Why does my 1984 chevy c10 silverado slow down going up small hills? I'm moving and pulling a uhaul behind me going back to Texas from Colorado.
An old exhaust converter could be partially blocked
The timing chain & gears could be worn
Egr valve issue
Worn valves that don't seal properly
Trans may be slipping or lock-up in converter is stuck on
Only so much guessing we can do
You have to test things one at a time
Oct 02, 2014 | Cars & Trucks
Can I lay down an Imperial Heavy Duty Upright Freezer for transport in a van or must it be upright in a pick up?
It should be upright, but if you must, after standing it up again - don't plug it in for couple of days. When it's down, oil in the pump moves quickly, but when it's upright again it takes it's time. If you plug it in too early, pump will overheats and you will need a new pump. Hope it helps.
Apr 30, 2014 | Freezers
I just got a 26 ft uhaul 1989 7.3 im trying to get the repair manual how do i go about doing that
I'm no expert on vehicles, but i don't think that vehicles come with repair manuals. Normally, car repairs require people with training, as cars and trucks are extremely complicated machines with hundreds of moving parts. If you need it repaired, go see a mechanic.
Feb 03, 2011 | Computers & Internet
Hi. I have a 1990 Ford F350 diesel UHaul with no
when you replace the master cylinder, your are supposed to pump it up manually before you install it. If you don't, you'll have to sit there and pump the brake pedal a couple of thousand times as one almost microscopic air bubble at a time escapes the pressure tube and back fills with fluid. once you can push the pedal repeatedly without any bubbles escaping into the reservoir, then bleed the brakes. Starting with the farthest, usually the Right Rear and work your way up. Make sure you keep the fluid level topped off. If it sucks air once, you have to start all over.
Sep 23, 2009 | 1990 Ford F350
While replacing motor coupling and vigorously moving motor gearbox around, something dropping on the base of drum but could not see what it was. And after completing the motor coupling job , I set the...
those pins are not important they are there for transportation purposes such as moving from one home to another or country don't worry about them. As far as the shaking and walking use a level and level your machine in both directions.
Mar 25, 2009 | Kenmore 24032\24036 Top Load Washer
Power ramp does not work.
Ignore everything above - most of the time this is an easy fix. Usually, it happens with a brand new console, or a machine that has reset itself.
Hold down the incline up (on the console itself) button and the start button at the same time. Then follow the instructions on screen.
It will run through an initial calibration, and once complete, the ramp will now work. Just did this with mine, and my ramp is now working perfectly.
Mar 19, 2009 | Exercise & Fitness
Printer/Fax machine
find solution
http://canon-resetter.blogspot.com
http://epsonresetter.blogspot.com
Mar 19, 2008 | Brother MFC 6550MC Laser Printer
Turning on
we moved in a uhaul across the US. Moving from one place to another has got nothing to do with tv operation. if it takes more time for light to come then it is a problem in brightness ckt or tube getting weak if tv is old tv. if on the whole more time means cap in power supply might be a problem good luck.
Sep 26, 2007 | Televison & Video
Ricoh Aficio 2018D All-In-One Laser Printer Logo
485 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
