Question about Honda 8 HP Engine
Looking at a bed edger and the compression is 90 psi is this something that i should worry about.
Looking at a brown bed edger and the compression is 90 psi is this something that i should worry about. it has the 8hp honda motor.
  • 885 Answers
The Honda 8HP motor will work OK with 90 psi compression but it's on the lower end of good. Most likely it will need new piston rings and possibly the cylinder resurfaced in the near future. Low compression could also be caused by valves not seating completely either from wear or carbon buildup. Depending on what you are looking to spend it may be worth your while to remove or have removed the head to inspect the valves and cylinder wall.
Posted on Jan 23, 2013
3 Suggested Answers
  • 583 Answers
SOURCE: Won't start, new coil, weak spark,
if i remember correctly these have electronic ignition the module may need replacing but beforedoing any thing drastic try disconecting the oil alert wire that sometimes gives a bit of pain youdoit
Posted on Jul 27, 2009
LandaNW
  • 45 Answers
SOURCE: 13hp honda motor what is the right psi for it
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Posted on Feb 14, 2011
2001 Scrambler 400. What should compression reading be?
With the decompressor active, nominal is 85 - 90 psi. At 62 psi, you have a top end problem. Try dumping a bit of oil in the cylinder and re-test. If the pressure rises, you have a ring seal problem. That sounds like an top end rebuild.
Oct 28, 2015 | Polaris ATV
What should the compression be running on all cylinders.
check the compression in all cylinders with all spark plugs out the numbers should be within 8psi of each other
Mar 29, 2015 | Boating
What should compression be?
The most common operating range is generally around 100 to 135 PSI for most 2 cycle engines. You need a compression gauge with short hoses for 2 cycle engines, the longer automotive one's will be off by as much as 35 PSI.
Oct 15, 2014 | Garden
Compression psi hyunda elantra
about 120 so this engine is well past its best or the head gasket has failed between the compression rings on the gasket
Jan 29, 2014 | Cars & Trucks
What is the psi compression on a 1998 kia sportage supose to be?
contact the parts store for specs they should have it on the computer system under overhaul specs..ask for a printout of rebuild proceedures..
Jan 19, 2013 | 1998 Kia Sportage
My peugeot zenith 50cc moped wont start , it cut out on me ridding down the road and I'm not sure whether its because I put a cleaner inside the fuel tank to flush out the engine. It now turns over...
What kind of cleaner did you put in the tank? Then you ran the unit with the cleaner in the tank? This is a two-stroke unit; correct?
Hearing that you put cleaner in the tank and that it now turns over faster than normal leads me to think that you have done internal damage to the motor.
Perform a compression test. Good compression is 140 to 160 psi. Anything below 90 psi means the motor needs to be rebuilt with new cylinder, piston and rings, crank bearings and seals, etc.
Oct 01, 2012 | Garden
98 honda accord v6 only has 90 psi compression
90 psi compression is the minumun for gas engine to ignite, you have low compression what is the compression next to it? The compression on Honda V6 is 200psi. you can have a valve problem a blown head gasket, Also make sure your compression gauge is accurate by using another compression gauge
Mar 23, 2012 | 1998 Honda Accord
What should a 98 dodge 5.2 compression be. Its in a 1500 Ram if that makes a difference.
GOOD COMPRESSION SHOULD BE 120 - 175 PSI IF COMPRESSION 100 PSI ACCEPTABLE. 90 PSI LOWER CYLINDER WEAK IF COMPRESSION 50 - 20 BLOWN HEAD GASKET.
Jul 05, 2011 | 1999 Dodge Ram
What is the avarage compression
At 55 PSI it will be hard to start and at the end of its life. 80 to 90 psi is the top range.
Jun 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Mar 30, 2009 | Garden
Honda 8 HP Engine Logo
81 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
