Question about Hitachi Televison & Video
Magic focus on my 60" Hitachi isn't working.
The magic focus isn't working, there's a blue line at the top of the screen.
  • Hitachi Master
  • 3,459 Answers
If your magic focus is not working your convgence has failed. Read this Tips page here on fixya for more details.
Posted on Jan 31, 2013
yankeegurl
  • 121 Answers
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: Magic Focus does not fix the blue 57UWX20B Hitachi
you need to replace the convergence ICs they are STK392-110 you can get replacements at the following link and they send instalation instructions with pictures so you can do the repair yourself. You need to replace both IC they are both STK392-110 they are located on the large heat sink on the far right side of your Tvs' chassis Heres the link for replacement ICs
Posted on May 20, 2008
experttv
  • 203 Answers
SOURCE: hitachi tv magic focus does not work
Your problem is the convergence circuit. This is very common in CRT projection sets like yours. There are a couple of IC's that need to be changed and possibly some resistors. A good repair shop will run you $400-$500 to do the repair.
Posted on Oct 28, 2008
ladywinn
  • 5138 Answers
SOURCE: hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Posted on Dec 30, 2008
ladywinn
  • 5138 Answers
SOURCE: Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Posted on Feb 16, 2009
My hitachi 60"ultravision tv has a double image at the top in blue and yellow. the magic focus has no impact. any ideas?
Pretty common failure with rear projection CRT sets.
Sounds like one of your convergence amp chips have gone out.
You can buy the chips from several vendors, or kits.
Do a search with your model number and "convergence amp chips". Shop around for the chips as they seem to be getting cheaper as this type of TV isn't as popular as they once were.
I've picked up several used Sony and Mitsubishi sets for nearly free that had this problem..
Feb 16, 2015 | Hitachi 60SDX88B 60" Rear Projection...
Hitachi 51S700 won't turn off
Some kind of a problem likely in the magic focus area--is the set showing a error on screen if you engage the magic focus?
One thing not to do is disconnect the sensors inside the screen as that could make things worse......
Dec 02, 2012 | Hitachi 51S700 51" Rear Projection...
Hitachi projection tv 53SDX01B is out of focus how do you reset.
if magic focus will not correct convergence problem look in the customer menu for the word CONVERGENCE---IF BLUE WILL NOT ADJUST IN some direction, one of the two Stk-392-110(or 392-150) convergence Ic chips are bad; you may also find some burnt or discolored resistors behind them----this kind of problem is usually fixable right in your home; if you need direct help;;;
etower.766@netzero. net
If this was helpful I would appreciate a vote from you here.
Aug 14, 2009 | Hitachi 60V715 60" Rear Projection...
Blue outline on the top half of the picture on my Hitachi 51F500
your convergence ic is going bad. usually worth the repairl.
Jun 04, 2009 | Hitachi 51F500 51" Rear Projection...
Feb 15, 2009 | Hitachi 57F500 57" Rear Projection...
HITACHI 43UWX10B Color Convergence
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Apr 28, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi tv
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Jan 27, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi53SDX89B color problem
Blue convergence IC bad...have both IC's changed..insist on
STK394-160E upgrade part # CZ 01341 Hitachi brand.....Original part is STK392-110......Also, check B+ feed resistors next to
convergence amp IC's for burn / damage...after rebuild, press magic focus.......................T.
Dec 21, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Blue/Yellow out of focus on Hitachi 43UWX10B
You will need the convergence circuit repaired......IC's replaced,
B+ resistors checked and then magic focus activated......T.
Sep 17, 2007 | Philips 60P8342 60" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
