Question about Sony KP-46WT510 46" Rear Projection HDTV
The colors on our Sony KP46WT500 do not line up on the screen. We have unplugged the tv to reset it but the colors still do not overlap each other into one picture. Is this something that is relatively cheap to fix? The tv is 6 years old.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    You can fix TV problem if you have basic electronic knowledge and little experience of TV repair.
    It is problem of convergence out ICs failure.
  • Sony Master
  • 8,617 Answers
You van get the repair kit at the following link which has both convergence ICs, the six pico fuses and four of the feed resistors plus the instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/sony-kp46wt510-convergence-repair-kit/cName/convergence-repair-kits
Posted on Feb 01, 2009
Sony Bravia flat screen TV when turned on has black screen. Green light on the bottom is lite up, electric plug is plugged into house socket, no picture only black screen.
If audio is OK, the fault is with its backlight section. If audio too is absent, the fault is with its digital main board. If you wish to get more details visit the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Jan 08, 2017 | Sony Televison & Video
Vertical lines on my plasma tv
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 08, 2017 | Samsung Televison & Video
WHERE IS THE RESET BUTTON ON MY TV
What is the brand name and model number of the TV. Can't say anything without these information. If the set is not too much older model, there will be no such button marked as "reset". For modern sets, if you have to do a reset, you should enter its service mode. It is somewhat skilled procedure.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 08, 2017 | Televison & Video
Toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 07, 2017 | Toshiba Televison & Video
The color on my TV is all pink. I have tried a hard reset but it didn't help.
Your TV has lost a GREEN color from a basic color palette (Red-Green-Blue). It is often caused by:
- damaged LCD cable (which connects the display with a signal board inside the TV),
- damaged video signal cable (ex. SCART, HDMI, VGA),
- damaged video processor (on the signal board).
I can't give you a more accurate answer, because I don't know what is your TV mark and model and, in what situations you have the problem.
Jan 19, 2015 | Televison & Video
How do I reset the TV?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 18, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
The word "Debug is on my tv screen. How do I remove it?
Unplug the power cord of the receiver box for 10 seconds and then plug it back.in job done..
Mar 23, 2014 | Televison & Video
Plasma tv sony need help
hi could be the cable connecting from the inverter to the lcd.
May 19, 2013 | Televison & Video
Tcl tv line through screen
maybe vertical ic be came hot and make some lige unconnected in board have to go to tv tichnican
May 18, 2013 | Televison & Video
Sony KP-46WT510 46" Rear Projection HDTV Logo
165 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
