Question about Balboa Instruments Duplex Digital Panel 2 Pump
I have a Leisure bay spa with Balboa LB501S Elect. system.One of my pumps burned out and was replaced. New one runs hot and kicks off. Found that the pump supply plug " J7" is only furnishing 120Vac. If I plug it into the second pumps plug "J6" the new pump works Fine.
Ian  Hot Tub
  • 77 Answers
SOURCE: I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
http://hottub.synthasite.com
Regards,
Ian.
Posted on Apr 01, 2010
Coastsider
  • 331 Answers
SOURCE: I just bought a used
This does not sound normal, but in order to better diagnose this I need to know exactly what model of controls your spa has. This is easily found on a label on top of the control box in the spa cabinet. If the label is missing, then remove the control box cover and look at the inside of the cover for the schematic, should be a model number on it.
Posted on Aug 30, 2010
ZJLimited
  • 17970 Answers
SOURCE: error code "OHH" displayed when
OHH code means "Overheat" condition
The spa has shut down -one of the sensors has detected 118 ° at the heater. Check it and replace it if go to bad.
Hope helps.
Posted on May 25, 2011
SOURCE: I have the Balboa 500Z pump heater kit. Its hooked
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
Posted on Jul 19, 2011
SOURCE: I have just refilled by
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
Posted on Sep 12, 2011
I bought a used Leisure bay Proshield hot tub and looking for an owners manual
I found a link on Google to download the PDF format. www.thespasyndicate.com or www.SpaParts123.net.
Sep 28, 2017 | Leisure Pool & Spa
Dont know what the name of my leisure bay hot tub is model number on pump says spo7211nca
Okay, those numbers mean nothing, and it's just pertaining to a electric motor that is attached to a wet end, which makes up a pump.
what is your question for this forum, if you are seeking assistance? Do you have a problem with this spa?
Apr 07, 2015 | Leisure Pool & Spa
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
How do you turn a balboa spa on?
FYI...
Balboa does not make spas, just control systems.
but that is enough info to begin a troubleshoot process...
  • do you have anything displaying on topside control panel?
  • Fault codes?
  • When you say no power after connection to circuit what do you mean exactly?
  • Have you checked for burned system fuse?
May 04, 2014 | AO Smith Pool & Spa
Error code "OHH" displayed when
Hope helps.
May 25, 2011 | Balboa Instruments Duplex Digital Panel 2...
I just bought a used balboa hot tub and have no expertise. Does the pump kick in automatically even when you turn it off it will turn back on instantly? Is that normal? If it is not normal what could be...
Aug 25, 2010 | Balboa Instruments Duplex Digital Panel 2...
Hot tub with electrical issue
Hard to say but one thing to check is if the tub was empty when you filled it did you bleed the lines to be sure they were flooded. If the lines are air locked the controls may keep the spa from starting so you don't get any damage from running it dry. All you need to do is find the drain valve and open it till you get water. Try it again and see if it starts. I hope this helps.
Dec 23, 2009 | Pool & Spa
Balboa Instruments Duplex Digital Panel 2 Pump Logo
288 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
