Question about Walgreens Cool Moisture Humidifier 890-Wgn
How to clean the 890 wgn humidifier/lost manual
How to use
How do I fill the water tank. Can't find an opening where to put the water
May 03, 2014 | Walgreens Cool Moisture Humidifier 890-Wgn
Lost the manual. Can tap water be used or just purified water.
We have had a separate make for years and just use tap with no problems.It leaves a water mark on the water holder but it cleans off.If you have a water filter already on your tap or a Brita type container with a filter,feel free to use that too.Either way,it will not hurt the humidifier. Good luck! Greg
Aug 13, 2010 | Kaz 4100 1 Gallon Humidifier
Cleaning the filter
Here is the link for your manual:
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
How to clean your filter:
The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
They say the frequency that you will have to clean your filter depends on yoru quality of water. The harder the water you have the more you will have to clean it.
Good Luck.
Mar 12, 2008 | Hunter 33202 Humidifier
How do I clean the heating coil and the humidifier?
Gently wipe, chip, and scrape as much scale as you can. If more cleaning is necessary, soak the pieces in vinegar.
Mar 12, 2008 | Clarion DA-1030 Humidifier
Walgreens Cool Moisture Humidifier 890-Wgn Logo
179 people viewed this question
Top Walgreens Humidifiers Experts
Dennis
Rich Brown
Tom Chichester
Are you a Walgreens Humidifier Expert? Answer questions, earn points and help others
