Question about Whirlpool RBS275PD Electric Single Oven
My bake element comes on when I press broil, broil does not work, no power from the lead coming from control board
The lead coming from the thermal fuse, to the broil element has voltage, but the other lead does not
    Genius:
  • 1,669 Answers
Change out the broil element.
Posted on Jan 22, 2013
Maytag Oven. The bake do not heat, the broil is ok. what is the problem ?
Look at the wiring diagram... The manual reset Thermal Limiter Switch (part number 74008715), located on the lower rear insulation retainer can keep both elements from working, not one at a time... I would inspect the back of the bake relay for a burnt/failing solder joint. Swapping the BAKE and BROIL leads is an acceptable test, but if you put the bake leads on the broil and still get no heat: check the control relay. If the broil leads will not heat the bake element, you have a bad element or bad connection. Be sure to do all testing of the elements with at least one wire detached so as not to red a back circuit.
Jun 19, 2016 | Maytag Ovens
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
I have a Fridgidaire Model # PLEB30S8CCC wall oven. The broiler works fine. The oven is very slow to heat up, 20 minutes to reach 250. I checked the lower element with a omp meter it read 20. Is that...
Hello there and than you for choosing Fixya
If your oven does not heat, does not heat enough or does not broil, a common cause is a burned out heating element. There are two elements, the baking element on the floor of the oven and the broiling element on the ceiling of the oven. They are about the diameter of a pencil and typically supported by metal stand-offs.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
When set to broil, the broil element should glow red, but the bake element typically is not used. If the broiler does not glow, it is likely a burned out heating element.
There are other possible causes of these symptoms, refer to our diagnostic page for some other possibilities.
To test the heating element using a multimeter, follow the steps provided below.
  1. Unplug the oven or turn off the power at the breaker or fuse box.
  2. Follow the heating element back to where it goes through the wall of the oven. Remove the bracket that secures the element in place.
  3. Unscrew or unfasten any stand-off supports that secure the element to the oven.
  4. Pull the element part way out to expose the oven's wiring connected the element.
  5. Label the wires and secure them in place so they do not fall back into the cavity.
  6. Disconnect the wires from the element.
  7. Using a multimeter set to x1, touch one probe to each of the element contacts. Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
  8. If the element tests okay, reconnect the wires, slip them back into the cavity and resecure the element.
Jan 26, 2011 | Frigidaire Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Nov 24, 2007 | Ovens
Whirlpool RBS275PD Electric Single Oven Logo
73 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
