Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer wont start, replaced push-to-start switch unit. still doesnt work.
  • 65 Answers
ENSURE THAT YOU HAVE POWER TO THE MACHINE AT THE BACK WHERE THE CORD CONNECTS. FROM THERE I WOULD TEST THE DOOR SWITCH. IF BOTH OF THOSE ARE FINE, I WOULD TEST CONTINUITY ON THE THERMAL FUSE MOUNTED ON THE HEATING ELEMENT. THERE ARE GENERALLY TWO THERMAL DEVICES ON THE ELEMENT AND IT IS THE SMALLER OF THE TWO WHICH IS MOUNTED HIGHER THAN THE OTHER. YOU SHOULD READ O OHMS ON A VOLTMETER. CHECK YOUR VENTING IF THE FUSE IS BLOW FOR ANY RESTRICTIONS
Posted on Jan 27, 2009
Wed5100v wont run
First, check the door switch to see that it is working. With the door open, push the switch and see if the light goes out. If it doesn't, replace the switch. Here is that part to order.
If the switch is good, then you need to replace the thermal fuse. Here is that part to order.
Dec 05, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Power is on but wont start on my Whirlpool Cabrio Dryer
The first place any tech is going start at is : Is the start switch working
I personaly have seen the plastic part that pushes the switch break and the control housing then needs replaced.
Jul 04, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer wont turn on
sounds like a bad door switch.
Dec 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Check the door switch actuator (the piece sticking down that the door actuates when closing . Could have broken off . If there , and you hear a click , then thermal fus (white piece with 2 wires attached ) could be problem . Disconnect power and put the 2 wires togather. Reconnect power and see if dryer starts . I have never had to replace a push-to-start switch .
Jul 14, 2009 | Whirlpool Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Dryer wont come on and light on the inside doesnt come on
this could be that your belt is broken there is a switch when the belt breaks it stop working thanks from gilles
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
96 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
